Farmpro 2430 hydraulic power steering
   / Farmpro 2430 hydraulic power steering #1
Rickpit
Yarmouth, Nova Scotia
FarmPro 2430
:confused: having issues with steering. Changed fluids in hydraulics two months ago and since can't steer properly. Steering is loose and have to move steering wheel a few rotations a lot of the time before can get wheels to move. Can't use in this condition. Has anyone else had similar issues
   / Farmpro 2430 hydraulic power steering #2
Have you checked for air in the steering circuit.
You may have a suction leak, hose or fitting, causing the air to impede you operation.
I'm not quite sure how to bleed air out of this type Tractor but have done what a Kubota dealer said to do if it was similar to what the this tractor has but it works no different than before. Right now I took it to a truck repair shop to see if they can decifer what the issues are. I'm not a mechanic and was frustrated and did not want to hurt anything further. I could use the tractor right now so took it to them. They are supposed to work on it today. Thanks for posting on this J_J and will keep you posted on what the shop may find. I posted this to see if anyone else ever had a similar problem. I'm hoping I'll hear from them soon and I'm hoping it may not be too expensive of a fix.
2016 John Deere 35G Mini Excavator (A49461)
2016 John Deere...
2002 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2002 Ford F-150...
2015 KUBOTA M5660SU 4X4 FARM TRACTOR (A51243)
2015 KUBOTA...
New Kivel Walk Behind Pallet Forks (A50774)
New Kivel Walk...
2022 Bobcat E88 Excavator (RIDE AND DRIVE) (A50774)
2022 Bobcat E88...
2021 GMC SIERRA CREW CAB TRUCK (A51406)
2021 GMC SIERRA...
