FarmPro 2425
   / FarmPro 2425 #1
Ed_B
Wisconsin
FarmPro 2425
I have a problem. I got my 2425 stuck clearing trails. I put in in 4WD creeper no go. I locked the differential and got out O.K.
Now when the left front tire is straight, the right front tire is turning to the right.
I know you are not supposed to try to turn with the differential locked. I don't THINK I did. The tie rod looks fine. Before I go trying to adjust out the problem with the tie rod I thought I would ask first.
Any help would be greatly appreciated.
All the info the forum has provided so far has been great!! You people are the best.
Thanks in advance.
   / FarmPro 2425 #2
That's something I would ordinarily attribute to a badly bent tie rod. But since you indicate that's not the problem, check to see if the steering cylinder came loose
//greg//
   / FarmPro 2425 #3
Is the tie rod behind the front axle still straight? If you got this hung up on a rock or stump and bent it, it would cause the wheels to "Toe-out" as you described.
   / FarmPro 2425 #4
You most likley, bent the tie rod, these are pretty easy to bend, you should be able to straighten it out if not we have the replacements
Tommy
Affordable Tractor Sales
   / FarmPro 2425
Feel kind of silly. Is the tie rod supposed to be bent? It looked like it was bent to go around the front differential.
Thanks for your replies.
   / FarmPro 2425 #6
</font><font color="blue" class="small">( Feel kind of silly. Is the tie rod supposed to be bent? It looked like it was bent to go around the front differential)</font>
Nope. Should be straight as an arrow.
//greg//
   / FarmPro 2425
Thanks Gentlemen. I have some wrenching and straightening to do, or I guess I will be giving Tommy a call for a new tie rod.
Great Forum! Wish I'd found it sooner.
   / FarmPro 2425 #8
I pretzled mine a few times, ended up getting a spare. One to use on the tractor, the other to straighten (again) in the vice.
Word of caution though. Make sure the threaded ends are never compressed in the vice, or you'll never get the tie rod back on the tractor.
//greg//
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
2014 Chevrolet Tahoe SUV (A50324)
2014 Chevrolet...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A52748)
2023 New Holland...
378741 (A51572)
378741 (A51572)
2009 MINI Cooper Coupe (A50324)
2009 MINI Cooper...
