FarmPro 2425 steering problem
/ FarmPro 2425 steering problem #1
kalebspop
Georgia, USA
FarmPro 2425
Can anyone tell me where the steering by pass valve is located on a FarmPro 2425? Mine tractor suddenly developed a quirk that requires me to <font color="blue"> </font> keep turning the wheel to maintain the tractor on a straight path. This tendency is much more pronounced if I am mowing on a grade.
/ FarmPro 2425 steering problem #2
Not quite sure why you're looking for a bypass valve, the problem you're encountering is most likely the seals in the steering controller. It's #30 in this diagram.
Also, check the nuts connecting both ends of the steering cylinder. You may have to peel back a rubber boot to get to the crown nut. See #3 and #11 on this diagram.
//greg//
Thanks, Greg. I was hoping that it would be easier to get to than the steering controller, but that's just my luck. I really do appreciate the help.
/ FarmPro 2425 steering problem #4
Bleed by in the steering cylinder will cause your problem. I have not seen any problems with the controller itself, so that is good news, easy to get to. These seals can be tested by turning the wheel lock to lock. the wheel should stop at each end of travel. If the cylinder is bypassing, the wheel will keep turning because the oil is going in and then right out of the cylinder.
/ FarmPro 2425 steering problem #5
</font><font color="blue" class="small">( I have not seen any problems with the controller itself )</font>
Your cylinder diagnosis may be correct Chip, but my hydraulic controller had a serious leak between the controller body and the bottom cover plate. Steering control was erratic and inconsistent. Depending upon how much resistance the turning wheels encountered, sometimes it refused to steer at all. That said, the location of the problem was obvious due to the significant amount of hydraulic fluid dripping onto the bell housing. I cut a new bottom seal (gasket) by hand, applied proper torque on the bottom cover bolts, problem fixed.
But you're both right. It's a ***** of a place to get at.
//greg//
Bluechip you have probably hit it on the head. My steering wheel will not stop turning in either direction. So I think I will have a go at the steering cylinder first. Thanks for your advice.
/ FarmPro 2425 steering problem #7
I just purchased a preowned 2425and my steering wheel wont stop turning. What do I need to do. Im new to the tractor thing.
/ FarmPro 2425 steering problem #9
And if you're not comfortable with repairing the guts of a hydraulic cylinder yourself, the whole thing can be replaced as well.
//greg//
/ FarmPro 2425 steering problem #10
Ouch:shocked: I think I'd learn how to use the repair kit in a hurry!
/ FarmPro 2425 steering problem #11
Its not hard at all. I did mine a few years back and it took longer to get it on and off the tractor. Whole job start to finish plus a new rubber boot on the steering cylinder was maybe a 1:15 job.
Chris
/ FarmPro 2425 steering problem #12
Farmpro has sold off most of there tractor parts too us in the last year ,since they quit selling tractors they also stopped bringing in parts also.All Farmpro tractors , Northern Tools Nortrac Tractors are the same tractors as the Jinmas, with the exception of a few parts all other parts are the same on Both.It's confusing enough for the Buyers of these tractors because of all the different names they are sold under,a Jinma Is a "JINMA " .
Tommy
Affordable Tractor Sales
"Your Jinma Parts Superstore"
Home of compact Jinma, Foton, and Koyker Tractors and Parts, Wood Chippers, Backhoes - Affordable Tractor Sales Company
2024 JOHN DEERE TURF GATOR (A63276)
2024 JOHN DEERE...
2020 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A67148)
2020 KENWORTH T680...
2016 Nissan Altima Sedan (A64557)
2016 Nissan Altima...
2015 Gravely ZT 42in. Zero Turn Commercial Mower (A64194)
2015 Gravely ZT...
UNUSED SDLANCH SDL2030GT-20' X 30' PREMIUM HEAVY (A64281)
UNUSED SDLANCH...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2017 FREIGHTLINER...
