farmpro 2420 hydralics
   / farmpro 2420 hydralics #1
steve1951
farmpro 2420
i have friend that recently purchased a farmpro 2420. We are trying to replace the hydralic fliud and have no idea where to pour the new fluid in. We donlt have any manuals for the tractor and we want to make sure we are pouring in the correct spot. Can someone help that may have one?
   / farmpro 2420 hydralics #2
Behind the seat , on top of the lift box.
Dip stick / fill hole.
Most were painted RED.
   / farmpro 2420 hydralics #3
More or less under the seat. I found it easier to just remove the seat (4 bolts) when changing the hydraulic fluid.
Sounds like you already found the drain plug on the rear of the tractor. I couldn't find it until a TBNer told me where it was.
There's also a soup can sized filter screen that sits in the sump under that three-bolt fitting just forward of the fill plug. You should remove it and clean it.
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
3 Point Hitch Boom Pole (A51573)
3 Point Hitch Boom...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A53472)
2016 Ford F550 4x4...
New/Unused 7ft 20 Drawer Stainless Steel Workbench (A51573)
New/Unused 7ft 20...
2020 CATERPILLAR 279D3 SKID STEER (A51246)
2020 CATERPILLAR...
MODERN AG PREDATOR 15 15' BATWING MOWER (A51406)
MODERN AG PREDATOR...
