farmers use undersized disc harrows?
   / farmers use undersized disc harrows? #1
tw30
Bronze Member
Reynoldville GA
want a tw30 2wd , nh-8870 2wd or puma 195 2wd
From what i gathered for every 15-20ft of disc you need 100hp.Biggest ive seen is 39'.Average large disc is 20-30ft.Why do farmer have 300+hp tractgors pu lling 30ft disc harrows ?Wouldnt the big case ih 335 magnum and steiger tractors pull a 60 ft disc harrow ? Now i know some famrer have feilds spread out and have to travel down the roads .But you could just tow one behind the other.When you get to the feild hook them sxs .I was thinking of hooking 5 International m37 disc together to get a 50 ft disc but they come in to many variable size's.but still connect 2 big plows or a bunch of smaller ones.See a bunch of used 30 & 20 ft disc from the 70's and 80's for around 5k and under .just thought to my self that a 30 ft disc is small for a 300+ hp tractor .I havnt seen any company that makes a 50ft or larger disc harrow . Also just throwing this out there the big bud tractor with over a 1000 hp wouldnt that pull a 120 ft disc.I thought most mid west or plains farm were self contained so to speak
   / farmers use undersized disc harrows? #2
I've been looking for a 3-point disc for my 39 HP John Deere 1070 tractor. After not finding one (at a reasonable price) I was able to use one that a neighbor has. It's a 10' disc and have no problem pulling it I'm not sure I buy the 100 HP per 20' of disc.
   / farmers use undersized disc harrows? #3
Size matters!! :) Really, I think it might sometimes be a case of wanting more tractor than they really need to improve the longevity of them. If you have a 100hp tractor and are constantly using it at the upper limit of what it's capable of doing, common sense tells you it most likely won't give you as much trouble free service as someone doing the same work with a 200hp tractor (all things else being equal). I also think that sometimes it might just be a simple case of one farmer trying to outdo the farmer next door!!:laughing:
   / farmers use undersized disc harrows? #5
TW,
Not an expert, but I see a lot of tractors towing tillage equipment down the roads. Size limits that are still road worthy could be a factor.
that 10'c you have could have smaller blades and weigh less might have lighter frames than other makes . Also athens makes afforadble plows + they make the largest 3 point disc i have seen 15'3" 3 point disc harrow .4x3 frame 7k for that with the bells&whistles .
I know outwest on the plains they have like 6000 acre fields they plow.And a 60+ ft disc would be great .though i dont won t to go into the disc building industry.those axles are confusing installing bearings,spacings etc .
   / farmers use undersized disc harrows? #7
Tw30, if you do some research on disks, you will see why there is such a big difference, maybe go to some AG shows and see for yourself. Some of the disks out there are 46-48" tall and over 1/2" thick, average 839lbs per disk. These things disk about 18" deep, that is a huge load to pull. You will also find that a lot of the time, they are actually doing 3 processes at one time and that takes a lot of power.
Do some research, most of the guys here don't deal with this big stuff and can't really help you out with these types of questions.
   / farmers use undersized disc harrows? #8
One reason is that many farmers feel they are saving money in fuel. The fuel economy is better if you aren't maxing out any engine. If the other tractors are in a strain or are running with the governers pushed to the stop, then fuel is flowing quite freely. Even though the larger engines consume more fuel on average, a lightly or medium loaded engine can consume much less fuel that a smaller engine/weight tractor that is getting all it can. When you can be dealing with a 10-15 gallon per hour consumption rate, it can make a difference over the long haul, if you are burning 3 or 4 gallons less of fuel. The newer engines are developing more HP at higher RPM's as well. Torque curves are different as well. Engines used to be low RPM (less than 1800 rpm) with high torque that peaked just below the max rpm. Now engines are putting out more HP at higher rpm's with a different torque curve that doesn't always fit the piece of equipment being used.
Another reason is that weight and slippage issues can be over come with heavier tractors. Tractors 30 years ago typically weighed more than they do now. That put a higher percentage of the HP to the ground. Now, heavier tractors are required to maintain the same pulling that used to be accomplished by a smaller hp tractor that was as heavy as the larger ones are now.
Also, you must consider if they are using 4 wheel drive in the recommendation. 4 wheels pulling can transmit much more power to the ground as well. This make a huge difference when pulling with marginally capable HP tractors.
   / farmers use undersized disc harrows? #10
GENIE GA1930 (A45046)
2006 LONESTAR UTILITY TRAILER (A45333)
2006 LONESTAR...
2011 Ford F-250 Pickup Truck (A42744)
2011 Ford F-250...
John Deere Utility Cart (A44572)
John Deere Utility...
2018 Ford Transit 350 (A44501)
2018 Ford Transit...
2006 Kawasaki KVF750B 4x4 ATV (A42744)
2006 Kawasaki...
