Farmall Super M Tires
/ Farmall Super M Tires #1
pratera
Tires are flat on my super M and won't hold air, are these tires tubeless?
/ Farmall Super M Tires #2
No...
/ Farmall Super M Tires #3
There is potential of it but I'd doubt it unless someone put new rims and tires on in the last five to ten years.
The valve stems will tell you, if they have nuts tighened to the rims they are tubeless
Is it possible just the valve stem is bad, since the tires went flat when the tractor was sitting in place for about a year, does this mean the whole tube needs to be replaced?
/ Farmall Super M Tires #5
It would be nie to know if they do have tubes! Another part would be loaded. My first thought would be to jsut air them up and see what happens.
If someone had put new rims on it and tubeless tires then yes it could be the valvestem but it also might be a bead leak.
You have to many ways that this can go for the info given to help much.,
/ Farmall Super M Tires #6
Never heard of replacing less than a whole tube...(grin). If the tires are truely flat and you know that no one let the air out on purpose, you can be pretty assured of two things...1) you do not have fluid in them otherwise the rims would be corroded at the stem. 2) you need new tubes. Once you get the tires off the rims, check the tires where they impacted the ground for "rot"...you may want to put a sleeve in the tire at that point. New 12.4x38s are not cheap....By the way, I've had Farmalls for most of my life and have never seen one on tubless rims/tires. BobG in VA
I got the rims off the ground fairly quickly and have had it jacked up since. I don't know where the air is leaking. I was thinking of putting a boot in the tires along with new tubes. Does anyone know where to find used tractor tires in east Texas?
