Farmall sickle bar mower
   / Farmall sickle bar mower #1
KubotaSam
Maine
Kubota B2410, Kubota B7100Dt, Kubota B7100HST
My brother was cutting hay with my Dads old Farmall super A. It has the factory sickle bar mower with a 7 ft bar. While mowing the cutter bar broke in half. I welded it but doubt it will hold. Does anyone know of a source for a new cutter bar for this farmall mower?
Thanks Sam
Thanks for the link. A Case/IH dealer about 2 hours away thinks they have a new cutter bar. Will drive tomorrow. I did not realize they would still stock parts for such old iron.
Sam
   / Farmall sickle bar mower #4
I have cut many acres with an A and a sickle bar mower. If you can't find one you might get lucky on craigs list. I see them there from time to time. Ed
   / Farmall sickle bar mower #5
Thanks Sam
The cutter bar on my Massey Ferguson 31 sicklebar was severely bent on the outboard end and had to be replaced.
I found the correct size steel bar at my supplier and just bit the bullet and drilled the hole pattern myself. Took a few hours of work on the drill press. No big deal.
Good luck
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
LMC G300JD LOT NUMBER 245 (A53084)
LMC G300JD LOT...
BUYERS PREMIUM & PAYMENT TERMS (A53426)
BUYERS PREMIUM &...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
2024 JOHN DEERE 8R 280 LOT NUMBER 7 (A53084)
2024 JOHN DEERE 8R...
27ft x 24ft Metal Building (A51573)
27ft x 24ft Metal...
