Farmall hydraulic leak
   / Farmall hydraulic leak #1
Tob
Salt point ny
Farmall super a
I own a 57 farmall super a with a single arm from bucket that has a hydraulic problem. I would appreciate any help out there. Tractor works fine whe. You are using the bucket. Recently i have had a road rake on the rear. When using the road rake the hy fluid is draining from the reservior for the bucket and being returned to the oil pan of the tactor. Not sure if that explaination makes sense. I end up with an overfilled oil pan and depleted hy fluid.
   / Farmall hydraulic leak #2
Check your pump shaft seal.
There is a florescent dye that one can put in the hyd system, and when a black light is shined on the area, the dye will glow a grennish yellow.
So if you pull the pump, and shine the light on the pump, if it is leaking, it will be obvious.
I know NAPA sells the dye, and probably other auto parts stores.
   / Farmall hydraulic leak #3
i agree.. you may have no relief the blew the shaft seal.. or it blew on it's own, and oil is bypassing thru the drive to t he pump...
2020 INTERNATIONAL RH613 MID-ROOF SLEEPER TRUCK (A53843)
2020 INTERNATIONAL...
2012 KENWORTH T800(INOPERABLE) (A53843)
2012 KENWORTH...
2020 CATERPILLAR 299D3XE SKID STEER (A52705)
2020 CATERPILLAR...
RIGID POWER DRIVE/HAND HELD THREADER (A53843)
RIGID POWER...
Utility Trailer (A52377)
Utility Trailer...
2020 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A52377)
2020 Caterpillar...
