Farmall F-20
   / Farmall F-20 #1
B3B
Rockford, IL
John Deere 314, Farmall A, B, C, M, F-20
What is the cylinder compression on a Farmall F-20?
   / Farmall F-20 #2
Compression ratio is around 4:1, due to, they were designed to run on distillate, and gasoline, known as an all fuel engine. If you've done a compression test, and it's around 55-60 psi, you're in the ball park.
2005 Sterling Acterra Tender Truck (A53472)
2005 Sterling...
Quick Attach Skid Steer Plate (A51573)
Quick Attach Skid...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
GODWIN CD150M DRI PRIME PORTABLE PUMP (A51406)
GODWIN CD150M DRI...
(30) Galvanized Steel Public Space Fence (A51573)
(30) Galvanized...
2008 OVERLAND TANK KILL TRAILER (A52472)
2008 OVERLAND TANK...
