Farmall Cub
   / Farmall Cub #1
North Georgia
Lula, Ga
Kubota9000 Farmall Cub
Bought another Farmall Cub last week and the guy was running a 12 volt battery but the tractor still had the six volt system. I know this will not run the lights but will it cause any other damage? Thanks for your help...
   / Farmall Cub #2
if he did not change the coil or add a ressitor, it will eventually ruin the coil and the points.. that is.. unless this is a magneteo ignition.
what year cub? in 66 they went to a 12v system..
soundguy
   / Farmall Cub
Thanks for the input..The cub is a magneto system
   / Farmall Cub #4
since it has a magneto system.. then you just need to get the charge system setup. either go back to 6v and use the stock genny on a 6c bat, and stock style lmaps.. or use the 12v battery, and get the genny rebuilt as 12v.. shouldn't be hard since a 12v version of that genny became available in 66.. should be easy to rebuild as 12.. then swap in new lamps. Starter won't care...but spins faster on 12v.. just don't grind on it forever or it will throw solder..
soundguy
2015 JOHN DEERE 624K WHEEL LOADER (A51406)
2015 JOHN DEERE...
2014 CATERPILLAR CT6605 SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
AMCO F42B-3626CS 13ft Pull-Behind Wheel Offset Harrow Tiller (A49461)
AMCO F42B-3626CS...
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
2009 Ford F-250 Ext. Cab Knapheide Service Truck (A50323)
2009 Ford F-250...
2014 Dynapac CC4200 Tandem Vibratory Roller (A51039)
2014 Dynapac...
