Farmall Cub
   / Farmall Cub #1
North Georgia
Lula, Ga
Kubota9000 Farmall Cub
Recently bought 2 restoreable Cubs and am having a problem getting one of them out of gear. Shifter appears to be disengaged but doesn't free up wheels. Anyone have a suggestion as to how to get it out of gear?
   / Farmall Cub #2
I see you're in GA but has it gotten cold enough to freeze? If so maybe there's water in the trans that's frozen. If that's not it could be bad/broken shifter fork. You should be able to shift the gears if you remove the shifter mech. I have a cub but have never had to get into the trans.
Here's a link to manuals you can download. Rudi's Farmall Cubs
M.D.
   / Farmall Cub #3
Are you saying the shifter appears to be in neutral? Had an A that would shift into 2 gears & lock everything up. Was from wear on the shifter & forks. Pull the transmission cover & move the forks by hand. A misalignment of the shifting gates is pretty obvious. You may have to rock the wheels a bit if something's under tension. MikeD74T
   / Farmall Cub #4
I'm thinking the same way as Mike D74T- you might be stuck in two gears. We had that happen to a 2-105 White years ago. It took opening the tranny, rocking the tractor, and the assistance of an independent mechanic to free it up. In our case, the hydraulic three speed power shifter was to blame(had to downshift to "underdrive" after that to shift the main tranny, as it was putting pressure on the hydraulic clutch). In your case, the tractor may have been shifted with the clutch partially engaged.
   / Farmall Cub #5
Interesting. My Farmall Super A won't shift into 1st gear. Looks like I'll be pulling the tranny cover soon and troubleshooting that problem.
   / Farmall Cub #6
That痴 a common problem with Farmal and a lot of other H pattern older shifters.
The fix is take the 4 bolts off that hold the shifter down to the gear box. Lift the shifter up with the plate, look into the top and you will see haw the sliders push the gearing your forks are worn a little and one side R-1 0r the other 2-3 has failed to move to the center neutral position. With your hand place both sliders into the center neutral position, replace the cover with the shifter in the neutral position and it should work fine until someone once again tries a speed shift, usually between R and 2, If it continues to happen you can either replace the shifter forks OR just build up the dimples at the fork tips with a little brazing rod. KennyV
Fcubs are a fun little tractor, I have one..
   / Farmall Cub #7
Thanks for the info. I'll try that as soon as I clear a space in the shop. One bay has the 1964 MF-135 diesel that's getting a replacement pto shaft seal. The other bay is cluttered with stuff for a welding project.
   / Farmall Cub #8
Great advice. I had the exact same thing happen to my farmall cub several years ago. Once I freed up the shifter I was careful to push it all the way in gear from then on.
   / Farmall Cub #9
Might also check the shifter nub.. might be wore down.. might be time for a little braze or weld and a file.
good luck and post back what you find with the cover off.
soundguy
   / Farmall Cub
I took the shifter cover off and it wouldn't move. Sprayed penetrating oil inside case and was able to get it in neutral..
Thanks for everyones help..
North Georgia
2016 FREIGHTLINER CASCADIA (A50854)
2016 FREIGHTLINER...
2009 Kaufman Gooseneck Trailer and 10K Hydro-Blast (A50860)
2009 Kaufman...
2023 Trailerman Gooseneck (A50514)
2023 Trailerman...
2018 Generac MLT6SM-STD3 6kW Towable Light Tower (A49461)
2018 Generac...
2014 Chevrolet Tahoe SUV (A49461)
2014 Chevrolet...
2013 INTERNATIONAL 4300 26 FT BOX TRUCK (A51222)
2013 INTERNATIONAL...
