Farmall Cub wont crank
   / Farmall Cub wont crank #21
Did you put a new 6 volt or 12 volt battery? Those tractors were set up on 6 volt systems. 12 volts has a tendacy to screw up the whole system.
yes and no.. and um.. no.
12v is fine on a machine that was setup for 6v..as long as you do everything needed to convert.
also.. in mid 1966 cubs went OEM factory 12v. not much changed except starter and genny windings and battery.. :) lamps.. etc.
Ford F250 Pickup Truck (A51694)
Ford F250 Pickup...
2025 New/Unused LandHonor Heavy Duty Plate Compactor (A51573)
2025 New/Unused...
23169 (A50324)
23169 (A50324)
2025 Star EV Capella 2+2 Electric Golf Cart (A51694)
2025 Star EV...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
2023 LMC H40024 LOT NUMBER 190 (A53084)
2023 LMC H40024...
