Farmall Cub Radiator Question
   / Farmall Cub Radiator Question #1
olgreyhair
NJ
John Deere 445
Hi all. I recently acquired a 1952 Farmall cub. It came with a property we purchased. It's all original and actually runs pretty well.
My question concerns the radiator fluid level. If I fill the radiator up and run the tractor for a few minutes or several minutes, after it builds pressure, it spits fluid out of the metal overflow line in the right bottom corner of the radiator. Not steam. Just fluid. So I don't know if this is just normal for a thermo syphon type system ( no water pump), or not. Will it spit out the excess fluid until it find the right level or should I be concerned? I did replace the radiator cap. I don't think it's overheating, no steam, just fluid. Any advice would be appreciated . Thanks. George
   / Farmall Cub Radiator Question #2
Often the right level is about 1 inch below the neck!
   / Farmall Cub Radiator Question #3
when it quits spitting it's the right level Make sure it's not blowing bubbles in the radiater after it stabilizesl bubbles could indicate a head gasket problem
greg
2015 MACK CXU613 TANDEM AXLE DAY CAB (A52141)
2015 MACK CXU613...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
Wood Fence Posts (A50121)
Wood Fence Posts...
Case-IH 580 Super N (A50120)
Case-IH 580 Super...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
