Farmall Cub Radiator Question
   / Farmall Cub Radiator Question #1
olgreyhair
NJ
John Deere 445
Hi all. I recently acquired a 1952 Farmall cub. It came with a property we purchased. It's all original and actually runs pretty well.
My question concerns the radiator fluid level. If I fill the radiator up and run the tractor for a few minutes or several minutes, after it builds pressure, it spits fluid out of the metal overflow line in the right bottom corner of the radiator. Not steam. Just fluid. So I don't know if this is just normal for a thermo syphon type system ( no water pump), or not. Will it spit out the excess fluid until it find the right level or should I be concerned? I did replace the radiator cap. I don't think it's overheating, no steam, just fluid. Any advice would be appreciated . Thanks. George
   / Farmall Cub Radiator Question #2
Often the right level is about 1 inch below the neck!
   / Farmall Cub Radiator Question #3
when it quits spitting it's the right level Make sure it's not blowing bubbles in the radiater after it stabilizesl bubbles could indicate a head gasket problem
greg
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A51219)
2019 INTERNATIONAL...
2021 Ford F-250 4x4 Ext. Cab Pickup Truck (A49461)
2021 Ford F-250...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
JOHN DEERE 3040 TRACTOR (A50459)
JOHN DEERE 3040...
2019 Ford F-550 Bucket Truck (A51039)
2019 Ford F-550...
2018 John Deere 460E Articulated Dump Truck (A51039)
2018 John Deere...
