farmall c wont start
   / farmall c wont start
got another warm spell in late feb. put originalstarter back on after i tore the pull switch apart and soldered the battery cable bolt from the switch directly on the starter contact. i then wired in a solenoid and regular key ignition switch where the power on/off switch was. works great. i did notice that the starter from my 1950 c broomed up the teeth on the flywheel a bit after just a half dozen or so starts.although the starters look the same the bendix drives must be a bit different.i would reccomend caution to anyone swapping parts back and forth or buyiny parts tractors of different years. i was lucky not to have to run it long enough to wreck my flywheel or the starter off my c.
i should make correction ...the 1952 is super c and the 50 is just a c and the starter bendix gear is different
2006 CEI  DRY BULK TRAILER (A58214)
2006 CEI DRY BULK...
2014 REITNOUER MAXIMISER 48' FLATBED TRAILER (A58018)
2014 REITNOUER...
2007 GMC 2500HD (A56435)
2007 GMC 2500HD...
2019 Peterbilt 520 Heil Side Loader Garbage Truck (A55973)
2019 Peterbilt 520...
Year: 2016 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A56859)
Year: 2016 Make...
VINTAGE EVINRUDE OUTBOARD MOTOR (A58374)
VINTAGE EVINRUDE...
