Farmall A
/ Farmall A #1
Ricn
Platinum Member
WA
Kubota U-35, kx-040, Ford 8n, JD-280, JD380, JD1020, JD40C, Satoh Bull, Kubota L2501,
So today I came into a very nice (I think) Farmall A. I know little about them so you guys will be seeing me here in the very near future. My son is getting this tractor for me through doing some driveway remodel whereby the owner says he wants to trade some of the work for his Farmall. Reports are it runs well but now needs a fuel filter and perhaps a new coil. The owner has been driving it in parades only so not used hard for many years. Can take pics when it gets here maybe next week.
/ Farmall A #2
A's are nice little tractors. If it has an inline fuel filter, that means the fuel tank has rust and other sediment in it. Hopefully the sediment bowl is still in place.
If that is the case, I'd advise removing the fuel tank and put some sharp stone, like limestone in it, shake it around to loosen/remove the crud. Some radiator shops offer a service of lining tanks, and there are some DIY liners too. I took mine to a shop and had them line it, solved my problem.
If it still has the sediment bowl, clean it well and install a new gasket. I prefer the cork one's that can be reused. Cheapest place I found to get them was from ebay, was like $12.00 for 10. But I have multiple tractors which use the same gasket, but someday you may need another. Doesn't hurt to have a spare on the shelf.
If it has a rubber fuel line, replace it with a metal line. I prefer brake line size should be 5/16". NiCopp brake line bends the easiest, although a little more.
/ Farmall A #3
Good luck with the "A", fun little tractors. I owned and used one for years even pulling a 5' bush hog.
/ Farmall A #4
Thanks for keeping yesterday's iron still alive. (y)
/ Farmall A #5
I'll start out with this disclaimer. I really like TractorByNet.
Yesterdays Tractors has a very large group of folks who are extremely knowledgeable about all things Farmall. (Website also covers lots of other "old iron")
I have a Farmall Super A - learned to drive on it.
/ Farmall A
Thanks for the replies and encouragement. Is this the correct place for discussing everything Farmall, mainly repairs questions etc. and for my "A" - if not, can someone lead me to the right forum, thanks!
/ Farmall A #7
Your good post away.
Good post away?
He meant: You are good (here). Post freely!
My dad picked up a 1948 Super A back in, oh, 1996 or so, and had it fully restored. It ran great for several years before our lack of maintenance kind of let it decay, and now it's been sitting dead for a decade. I look forward to bringing it over to my shop and tuning it back up eventually! One mistake we made was in not converting to 12V. Keeping 6V batteries charged was always annoying.
But right after restoration, our Super A was a joy to operate and a real workhorse. We plowed 16" snowfalls, dragged dozens of logs out of the forest, and towed yard trailers around. Amazing what 14HP can do with the right gearing and big wheels/tires.
I also have an "A", they are pretty good tractors.
They share parts with other sizes of Farmall's, so parts are pretty easy to come by.
SR
2008 Ford F-550 4x4 Landscape Dump Truck with Lift Gate (A61568)
2008 Ford F-550...
JLG Scissor Lift (A64047)
JLG Scissor Lift...
2009 Kubota RTV1140 (A57149)
2009 Kubota...
2005 Deere 317 Rubber Tire Skid Steer (A64047)
2005 Deere 317...
DRAGON TRAILER MOUNTED TRANSFER PUMP (A63569)
DRAGON TRAILER...
E-Z TRAIL HEADER CART (A63291)
E-Z TRAIL HEADER...
