Farmall "A"
   / Farmall "A" #1
AMP762
s.c.
Mitsu D1550 Farmall super A
I have just become the owner of this tractor and for now I have a couple of questions.What would be the best oil to use And is this a pos. ground system?
Thanks
   / Farmall "A" #2
AMP762 Yes it is positive ground. You may not know the light switch also contains the voltage regulator. The engines were built when straight weight was the rule so any straight weight depending on seasonal temp was used, modern multiweight now applies based on temps & consumption. Got pics ??? MikeD74T
   / Farmall "A" #3
Thanks
As was already stated look at the light switch, it should have a "B" for Bright and a "D" for dim as well as the off position. As far as oil, they ran well forever on 30W Non-detergent. No one I know now (I have 3 Farmalls now), runs anything but 15W-40 detergent oil. Does great with it. Make sure your oil pressure is good....You might try one of the many old iron websites such as "Red Power Magazine" and "Yesterday's Tractors". In that regard, there is a plethora of information on your "new" toy. Congrats and enjoy! BobG in VA
   / Farmall "A" #4
Yep.. that lamp switch used a tickle resistor to provide some extra field biasing.
I've been running sae 30 in my cub.. it seems to like it.
Soundguy
   / Farmall "A" #5
Thanks
Mornin AMP762,
I run a short #00 battery cable from the positive terminal to the top of the tranny case on both my A and Super A. As far as oil I use straight #30 wt unless its very cold durring the winter and then I go down to #20 wt. The tractor starts a bit easier for plowing !
Good luck with your new A, its a great tractor !
Toro Workman HDX-D Utility Cart (A53421)
Toro Workman HDX-D...
2016 PETERBILT 389 (INOPERABLE) (A53843)
2016 PETERBILT 389...
John Deere Gator XUV835M 4X4 Utility Cart (A48082)
John Deere Gator...
2021 Caterpillar 428 4x4 Extendahoe Loader Backhoe (A52377)
2021 Caterpillar...
2005 FORD F350 XLT SUPER DUTY SERVICE TRUCK (A51406)
2005 FORD F350 XLT...
