Farmall 75C radiator drain location?
   / Farmall 75C radiator drain location? #1
dukeboy66
Bloomington, IL
Case 75C L620 FEL
I am installing a block heater and I am not seeing the radiator drain. Do any of you happen to know where it's located or maybe have a better picture than the owners manual? LOL! the images are horrible.
   / Farmall 75C radiator drain location? #2
I don't see one on the parts diagram. Probably just take the lower hose loose from the radiator.
   / Farmall 75C radiator drain location? #3
It may not have a drain. After much looking I decided my old Mitsubishi lacks that feature. I just remove the lower radiator hose. It drains, I just have to carefully place the bucket to catch the fluid.
I didn't find one, even what the manual points to as the drain plug. I removed the plug below the freeze plug and drained it there, made quite a mess. Thanks for the replies.
2008 MACK CHU613 DAYCAB (INOPERABLE) (A58214)
2008 MACK CHU613...
2019 TerraGator 7300 Spinner truck (A56436)
2019 TerraGator...
2017 Ford F-450XL (A57148)
2017 Ford F-450XL...
2018 Toro Z-Master 6000 Series 74in Zero Turn Commercial Mower (A56857)
2018 Toro Z-Master...
17" Wheel Simulator, Front & Rear w/Hub Cap, Ford F-250 Chrome, 1 Set, Item # RZCMWC-9506 (A59076)
17" Wheel...
SKID STEER ATTACHMENT PICKER (A58216)
SKID STEER...
