Farmall 706 hydraulic control valve
   / Farmall 706 hydraulic control valve #1
Clint Lynch
Roswell, NM
International Farmall 706
My hydraulic control valves are leaking badly. Does anyone know of a rebuild kit? All I can find is a remanufactured valve for $625.
   / Farmall 706 hydraulic control valve #2
I'm going to assume this is the kit you mean. Hope all the links come through. Look clear at the bottom of the list, on both Case/IH online parts book. If you look at Messicks link, it give the price. Then Bates. It does show a picture of what all is included. Take that for what it's worth... Lots of hits using the part number, so you can copy & paste to a search engine if you want to look further.
Official Case IH Online Parts Store and Case IH Catalog for Best Parts Search and Best Parts Look Up. Case IH Parts for Case IH Tractors, Case IH Combines, Case IH Tractors, Case IH Manuals, Case IH Parts
Object moved
Products :: 383548R92 Package, Seals
Thank you. That is what I was looking for, but I thought I had seen it for $85.00 somewhere. Appreciate your help!
   / Farmall 706 hydraulic control valve #4
I just picked up a 706 tractor, and I am trying to change the hydraulics. I want to install a bucket and add lines in the back. I have 2 sets of lines in the back. Only 1 is working. The other set is hooked to a block at the back of the main valve. How can I get a pressure line up to a auxiliary valve for the bucket, and what is the 2nd lines in the back for?
New/Unused 48in Quick Attach Pallet Forks (A51573)
New/Unused 48in...
2003 Chevrolet 3500 (A50120)
2003 Chevrolet...
2025 New/Unused LandHero 16in Concrete Cutter (A51573)
2025 New/Unused...
2021 International HV507 4x4 12ft Single Axle Dump Truck (A51692)
2021 International...
2019 Freightliner M2 106 Sweeper Truck, VIN # 1FVACXFC1KHKF6139 (A51572)
2019 Freightliner...
