Farmall 400
   / Farmall 400 #1
joelaudi
Cheshire CT
1960 Case 430, 1947 Ford 8N, 1942 Ford 9N [not running], 5252 Cub Cadet to cut the lawn, John deere 140 , Sears SS12, Crafsman 5000GT, and a Gravley 816 which may be the most rugged tractor that I have ever seen.
This is a question for a friend. He has a Farmall 400 gas tractor. It seems to have no power but will idle ok and and starts right up. When going up hill or under load it will not make any power. The carb was cleaned with no visible signs of any clogged jets. Hope someone can help him out.
   / Farmall 400 #2
Good Evening Joe,
You didnt say if you checked the fuel flow from the tank to the carb ? Also was the float adjusted properly ? That could be a problem. In any event, I would ask this question over on Yesterdays Tractors on the Farmall forum. They have some great knowledge on that site.
I own two Farmalls but not the 400. Good luck !
   / Farmall 400 #3
Could be a couple of things, besides the carb itself. I'd check the governer first. Second, the distributor/coil setup, as sometimes the shaft driving the distributor can/does wear causing iexcess play causing it to vibrate under load and shutting down the spark....if it is, there is a fix....just a strange thought on old IH stuff
2015 KENWORTH T800 MID-ROOF SLEEPER (INOPERABLE) (A50854)
2015 KENWORTH T800...
John Deere 455G Loader (A48837)
John Deere 455G...
2014 Volkswagen Passat Sedan (A50324)
2014 Volkswagen...
2003 MACK RD6885S T/A DUMP TRUCK (A51406)
2003 MACK RD6885S...
2015 MACK GU713(INOPERABLE) (A50854)
2015 MACK...
2012 International Semi Truck (A50323)
2012 International...
