farmall 31
/ farmall 31 #1
hayman2042
2009 case ih farmall 31
I have a farmall 31 that had sat for awhile, after starting it would barely move and the peddle would shutter really bad and after 30 seconds it took off like normal. it then seemed to loose speed and would only move under low rms, now after sitting for a couple hours in the cold it wont move in any range. Has anyone had this happen before?
Thanks
/ farmall 31 #2
I have a Farmall 31, really doesn't like the cold if i leave it sit outside my shop. First thing i would do is change all the hydraulic oil and both filters. Most likely some water in the oil and causing filters to plug and cavitate. Don't run it. May hurt the pump. Place to start. How does your hydro foot pedal move as mine is very tough to move. I have grease that fitting under the floor board you can't hardly get to. Good luck. Im looking for rear remotes, any ideas where to find them?
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
1996 Chevrolet 1500 (A64127)
1996 Chevrolet...
2013 GMC Sierra 2500 HD 4x4 Ext. Cab Pickup Truck (A64556)
2013 GMC Sierra...
(INOP)1989 NISSAN D21 EXTENDED CAB TRUCK (A65054)
(INOP)1989 NISSAN...
2022 EZ-GO ELITE...
Mini Skid Steer (A60352)
Mini Skid Steer...
