Farmall 300
/ Farmall 300 #1
peanuthil12
farmall 300
I have to ask some advise here. I have a farmall 300 and I have found two check fluid plugs on the left side for hydraulic fluid. the one closest to the drive is fill from near where the shifter goes between my feet. when the check plug is out and the fluid starts coming out, I replace the plug, and that should take care of that one. The one ahead of it, closser to the front of the tractor has a fill point somewhere, but I can't find it. I know it has need of fluid because nothing comes out when removing the plug. Where do I fill the thing
Thanks
/ Farmall 300 #2
Thanks
Good Afternoon peanuthil,
This should probablly be posted in the IH board.
Anyways your fill plug on the Hydra Touch unit should be on the front right corner of the unit as your sitting on the tractor, close to your control handles.
I have the operators manual for an IH 350 Utility, if I can be of further help let me know !
2022 EZ-GO ELITE...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
2014 John Deere 644K High Lift Articulated Wheel Loader (A61572)
2014 John Deere...
2005 C7500 20' Box Truck (A62613)
2005 C7500 20' Box...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
UNUSED KUBOTA 48" PIN ON BUCKET (A64280)
UNUSED KUBOTA 48"...
