Quick Hitches farmall 2 point fast hitch to 3 point adaptor arms
   / farmall 2 point fast hitch to 3 point adaptor arms #1
chuckyou
phillips wi
farmall
looking for just the adaptor arms to convert my 560 2 point hitch to 3 point hitch somebody already has the mount for the top link on it
also having an siiue with the drawbar being too far out pto shaft on the haybine will come apart when its in road position any idea's
   / farmall 2 point fast hitch to 3 point adaptor arms #2
Iowa farm equipment has them. As do some other vendors. As for the pto shaft, you might want to pin it up when you are towing it.
   / farmall 2 point fast hitch to 3 point adaptor arms #3
haybine drawpin should be 16" from the end of the tractor's PTO shaft. If it isn't; it needs to be set there. If it is, your haybine shaft has problems.
thanks for the info
2021 International HV507 12ft Dump Truck (A51692)
2021 International...
UNUSED FUTURE MINI SKID STEER MOUNTING PLATE (A51244)
UNUSED FUTURE MINI...
2011 Hyundai Sonata (A50324)
2011 Hyundai...
UNUSED SWICT 60" QUICK ATTACH BUCKET (A51244)
UNUSED SWICT 60"...
2007 Generac QT06030AVAN 60kVA Gasoline Generator (A50322)
2007 Generac...
PALLET OF WALL PACKS (A51244)
PALLET OF WALL...
