Quick Hitches farmall 2 point fast hitch to 3 point adaptor arms
   / farmall 2 point fast hitch to 3 point adaptor arms #1
chuckyou
phillips wi
farmall
looking for just the adaptor arms to convert my 560 2 point hitch to 3 point hitch somebody already has the mount for the top link on it
also having an siiue with the drawbar being too far out pto shaft on the haybine will come apart when its in road position any idea's
   / farmall 2 point fast hitch to 3 point adaptor arms #2
Iowa farm equipment has them. As do some other vendors. As for the pto shaft, you might want to pin it up when you are towing it.
   / farmall 2 point fast hitch to 3 point adaptor arms #3
haybine drawpin should be 16" from the end of the tractor's PTO shaft. If it isn't; it needs to be set there. If it is, your haybine shaft has problems.
thanks for the info
2002 CASE INTERNATIONAL MX270 TRACTOR (A51243)
2002 CASE...
1992 Imperial Trailer (A50514)
1992 Imperial...
New 4x6 Chicken Coop (A50774)
New 4x6 Chicken...
Tandem Axle Silage Cart (A50774)
Tandem Axle Silage...
1986 Diesel C70 Grain Truck (A50514)
1986 Diesel C70...
2011 International WorkStar 7400 Chassis Truck, VIN # 1HTWGAAR6BJ325793 (A51572)
2011 International...
