Farmall 140
/ Farmall 140 #1
Crw
Farmall 140
I have a farmall 140 that some one is giving me it has not ran in a year or two
When u tried to start it last year it would
Fire up then it would die rite away can some one give me some info on what to
Do to get her up and running again
/ Farmall 140 #2
I wouold drain the gas tank and the glass fuel bow under the tank to start with and put fresh gas in to start.
/ Farmall 140 #3
sounds like fuel system problem to me. likely water and/or dirt in lines or float. dirt will settle out then when you run it ,stirs it up until it blocks the carb orifice. other thing to ck is on the glass sediment bowl make sure the petcock is open, may ahve been turned off.
clean and blow out everything and put in fresh fuel with a good carb cleaner additive to remove gum and varnish.
/ Farmall 140 #4
starting then dieing generally means lack of fuel thru the fuel valve or float needle seat.
assuming points are not burned.
soundguy
/ Farmall 140 #5
Hi all. New user here but have spent a long time "lurking". I read this post and I think I may have some info to fix it. My father in law has an older Alice chalmers about the same size and vintage. He had a similar problem. It would start and then instantly die. As if all four cylinders would fire once only then die. After four hours of trying to diagnose it, he gave up and called a local equipment repair facility. They spent a lot? of time working on it and finally figured it out. Apparently there is a spring in the distributor that was broken. From what I gathered from my father in law, the spring kept pressure on a gear that keeps the motor in time? I would try taking the distributor apart to make sure nothing is broken/rusted. Some of the earlirer posts have already suggested looking at the points, which is very good advice. Especally on a tractor that has been sitting. It's not that much harder to keep taking the distributor apart to see what else is going on. Sorry if I stepped on any toes and sorry to be long winded. I'm going to head over to the new member introductions tomorrow to formally introduce myself. Good luck!!
/ Farmall 140 #6
that would be the very last thing I would think of when it starts fine and stalls.. IMHO
soundguy
/ Farmall 140
Yes it's a good idea to keep you from scratching your head all day I wouldn't have thought to check that but it runs for about ten seconds then stops it sounds like the timing is on so hopefully it just a fule system issue
/ Farmall 140 #8
It probably wouldn't even start if timing was off.. so I'd save that wild goose chase for another day..
soundguy
/ Farmall 140
Yeah I would half to agree with you do u think it is a good idea to add a inline fule
Filter
/ Farmall 140 #10
generally the inline filters cause more problems than they solve, as there should already be a sediment bowl there. if you have chronic bad gas or tank problems you can't address.. then you could add a fuel filter made for a gravity feed lawnmower.. etc. IMHO, it's not prefered.. but sometimes you do what you have to do..
soundguy
/ Farmall 140 #11
Guss I should have asked for more info first. Runs for 10 seconds and dies is different than starts and dies right away as stated originally. I would agree that some new fuel and clean/replace filters should do the trick. Best of luck!
/ Farmall 140 #12
Close off the fuel at the bowl under the gas tank..then take the fuel line loose at the carb...these are metal lines (from the factory)..at the fuel line connection at the carb you will find a brass "strainer"..see if its clogged..if so you have found the culprit..also look in the tank with a good flashlight and see how much "rust" is in there around the walls etc. Once you do that come back and tell us what you find...BobG in VA
/ Farmall 140 #13
Ditto.
Also, give a couple of good whacks to the outside of the carburator. Good chance you have a sticky float after sitting for so long.
/ Farmall 140 #14
Hello Crw. My first guess would be fuel. BUT, did you check for a spark after it dies??? If you don't have spark when you let the key go, Not while turning it over, but when you let the key go. To test, use a jumper wire from the battery to the coil. If it keeps runing you have an electrical problem, from the key to the coil.
Dave
/ Farmall 140 #15
Dave
That is the direction I was headed with my first post, losing spark. After talking with my father in law again about what happened, the broken spring was some sort of a automatic timing advance/****** to assist when cranking the motor by hand. Not motor timing as I mistakenly first said. Once the motor fired it was suspossed to return to normal timing. His tractor didn't sit for a couple years, it ran fine then 3 hours after being parked it would start then imeadeatly die. I think the problem is fuel related after learning that it runs for 10 seconds then dies. Im anxious to hear what it is. Good luck!
/ Farmall 140 #16
I have a Cub Lo Boy that the sediment bowl cork gasket was deteriorated in. The little pieces of cork would clog the outlet and cut off the flow of fuel. You couldn't see anything and the bowl was clear so was a bit frustrating:mad:
/ Farmall 140 #17
any further progress yet?
soundguy
2018 Manitou MLT960 ST4 S2 13,000lb 4x4 Rough Terrain Telehandler (A66734)
2018 Manitou...
2015 Jeep Cherokee 4X4 SUV. (A66738)
2015 Jeep Cherokee...
2006 7X12 Lark S/A Enclosed Cargo Trailer (A66738)
2006 7X12 Lark S/A...
2014 Ford F-250 Knapheide Service Truck (A66736)
2014 Ford F-250...
2020 ISUZU NRR 4X2 S/A 22FT BOX TRUCK (A59912)
2020 ISUZU NRR 4X2...
PANTHER T14R TRACKED DUMPER (A65056)
PANTHER T14R...
