Farmall 100 grinding gears
   / Farmall 100 grinding gears #1
Ramon
NC
Farmall 100
My Farmall 100 has a rough time getting in gear. When the clutch is fully depressed, I usually have to hold it for 10-15 seconds and keep trying to get it in gear. Usually, I end up still having to grind it a bit and force it into gear. Based on what I have read, it sounds like there is an easy way to tighten some yoke rod or toggle the yoke rod but it isn't clear. Hopefully, I don't have to take the tractor completely apart to tighten the clutch (which I believe is the problem). Any thoughts?
   / Farmall 100 grinding gears #2
These transmissions have straight-cut gears with no synchronizers, it's probably just simple inertia keeping the gears moving once you depress the clutch. My 130 is the same way. As long as the gears eventually stop moving and you can engage smoothly, then there is probably nothing wrong. Thicker trans oil may help them slow down.. check the level as well.
- Patrick
Unfortunately, the gears rarely stop moving completely and thus I find myself clenching my teeth and having to actively grind gears about 75% of the time. Also, the clutch pedal has way too much play, about 3 inches and that should be easily correctible, or at least I hope so ;-) if I only knew how.
   / Farmall 100 grinding gears #4
I have the I/H shop manual for the 130, I'll look up the procedure when I get home and post it. You should only have 1/2 inch of free play before the throwout bearing hits...
- Patrick
   / Farmall 100 grinding gears #5
The manual doesn't say much, it just says to adjust the clutch by varying the length of the clutch actuating rod with the nuts until the there is free travel of 1 to 1 1/4 inches. Procedure is the same for 100 and 130. The location of the nuts appears to be obvious from the drawing, just back from the pedal itself. Give it a shot, looks easy enough.
   / Farmall 100 grinding gears #7
Double clutching probably wont help much if these are straigh cut spur gears in a non synchro tranny. Even if spinning slightly.. they will slide out of gear fine.. it is just getting them in gear that is the bear.. if the clutch drags.. etc.
Soundguy
   / Farmall 100 grinding gears #8
The reason the gears keep on spinning is because the clutch disc isn't retracting from the flywheel far enough. Lube the splines where the disc slides with wd-40, and only then you'll be fine. I've worked on hundreds of farmalls so i know what i'm talkin' about here
   / Farmall 100 grinding gears #9
</font><font color="blue" class="small">( the clutch disc isn't retracting from the flywheel far enough )</font>
Yeah.. that would make the clutch drag..
</font><font color="blue" class="small">( I've worked on hundreds of farmalls so i know what i'm talkin' about here )</font>
Except that cubs with battery ignition systems DO have spark advance... /forums/images/graemlins/confused.gif /forums/images/graemlins/tongue.gif
Soundguy
   / Farmall 100 grinding gears #10
I thought a bit about this...
Is this happening when you initally go to put it in gear, or does it happen when shifting? I ask, because these tractors are not made to shift; if you need 3rd gear, you start out in 3rd gear, or which ever may be the case. I tried shiftin my "A" like a car, and ground 'em...
I find too, whether the tractor or a car, sometimes if it does not drop right in gear, I will try reverse, then the gear I want. I don't release the clutch, when doing it; just slip it between. It usually goes right in to the gear I choose then. Must be something lining up that was just off a little.
Otherwise, it may be a mix of adjustment, lubrication ect too, as mentioned by other posters.
CAT Skid Steer (A50322)
CAT Skid Steer...
FRONTIER WR3210 LOT NUMBER 120 (A53084)
FRONTIER WR3210...
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
2012 CATERPILLAR 279C2 SKID STEER (A51242)
2012 CATERPILLAR...
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
20ft Utility Cargo Trailer (A51572)
20ft Utility Cargo...
