sixdogs
Super Star Member
- Joined
- Dec 8, 2007
- Messages
- 13,238
- Location
- Ohio
- Tractor
- Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
Here's bunch on Harbor Freight HVLP spray guns
It has to be this one. Looks like same gun with two makers. It's 20 oz, not 2 oz,
2 oz. HVLP Gravity Feed Air Spray Gun with Regulator
Don't buy this $70 one below unless you are painting cars. I have one and it's not much different than the above for farm spraying.
2 oz. Professional HVLP Gravity Feed Air Spray Gun
Here are the paint cups and wire stand. These are a must so get two packs of cups. Don't use the screw-in adaptor. Mine leaked so just screw the paint cup onto gun.
5 Piece Air Spray Gun Disposable Paint Cups
The paint gun stand I like looks like this below but I can't find on the net right now. It's in the store.
You also could use some HF paint filters, especially if you store partial cans. I have but don't use very often. You'll need a metric hex wrench to put the stand on and remove for cleaning and a toothbrush. You should also have a water trap on your compressor. Set your gun pressure with the trigger pulled and air flowing on a cleaned gun.
I spray and when done, immediately rinse cup with a little acetone and spray clean. I disassemble what I can, soak the nozzle, etc in acetone and blow clean with compressed air while wearing goggles. Also, acetone is acetylene (get at WalMart) and highly flammable so I keep outside as much as possible. I don't work directly under my overhead lights while cleaning and pouring the stuff. Keep rags outside. Wear thin rubber gloves.
You have to thin Rustoleum more than you think. A splattering finish usually means too thick of paint. I spray Rustoleum primer on hot days and wait maybe a half hour or longer. Then I light spray the color coat, wait a few minutes and slightly heavier coat once or twice. If using good OEM paints, you will be thrilled at the results, especially when compared to farm store paints. Please, forget those and the few percent savings. When you first open the can, punch some small nail holes around the rim of the can so paint can flow back. If you have a partial can, put the lid on and store the can upside down so it doesn't skin over. Just do it; you'll see. Filter stored paint.
Here is a lo-buck Harbor Freight paint gun job with OEM acrylic enamel paint.
How's that for "pop"? Here's the thread.
1950's Dearborn cultivator find and rebuild
There are a number of threads I have done like this. Search for more if you care.
Anyway, have fun and post pictures. I've done this for decades and the HF HVLP paint gun is among the best there is, especially for the price. It's a fine reward to restore something to a respectable facsimile of it's original state.
EDIT--When painting, I wear those typical "Tee shirt" type bags on my feet that are available everywhere. Just find some beefy ones, put your foot in and tie the tops together. It looks dumb but keeps my boots the rustic brown leather color I prefer rather than Kubota Orange or JD Classic Green.
May I be the person my dogs think I am,
