Farm tractor models to avoid
   / Farm tractor models to avoid #31
Cavitation erosion and electrolysis damage to parent bore and wet sleeved engines are maintainence problems, not engine problems. Both are preventable situations that can affect any engine of those construction types regardless of brand or paint color.
Is it not true that certain models are much more prone to this?
Thanks to all that posted, I'm looking for an older tractor 60-90 hp maybe more for occasional use in the fields, maybe 30-50 hrs a year tops. Probably close to 20-30 hrs. just for plowing and disking if I find a nice disk for a fair price.
I've been looking at a few 86 series IH tractors and there's a 986 with a new ta for sale local for a fair price. My young son 5yrs old wants daddy to buy green, thanks to my neighbor. Maybe I should buy an Oliver:)
I do see a few Whites around but don't know much about them other than their oliver connection there's always an old 2-70 through 105 for sale and they don't seem to have a large used following as other models do. Is there a reason other than it being agco?
   / Farm tractor models to avoid #33
Having put on over 2000hrs on a White 2-105 I'll give you my opinion. The Perkins engine had a different -# then the Massey's and was hard to start. Replaced it with a Cummins 5.9. The brakes left lots to be desired and the noise in the cab was loud. Put in new interior to quiet things down but it was the loudest cab afterwards too. The John Deere and Ford cabs of the same era were much quieter. I only used the 2-105 when the other colors were busy.
   / Farm tractor models to avoid #34
Cavitation erosion and electrolysis damage to parent bore and wet sleeved engines are maintenance problems, not engine problems.
In some cases they are poor quality casting problems conveniently hidden under the Cavitation designation.:D
   / Farm tractor models to avoid #35
Theres a man redoing some gas stations here and he has a Long. Good looking tractor just stays a the hydraulics shop or an auto electric shop nearby. Heard both good and bad about the Belarus. Leary of Farmtracs, neigbor sold them. He sold some Lenars and a Jinma dozer, they are the bad pennies over the rest he keeps getting them back. On industrial tractors, had heck with an International swing motor on a 260 Backhoe, But most makers that time used a swing motor. IH had a backhoe ahead of its time but minor things killed them. Had some problems with a mans oliver I worked on, it was a Same tractor rebadged, The Companies that sell parts in Italy refused to sell me one clutch assembly and an alternator.
I worked for a company that had some older Long TLBs Parts were obsolete for them.
   / Farm tractor models to avoid #36
In the 80's Massey Ferguson went from the 1100 series tractors (which by the way are great tractors) to the 2000 series. The Perkins engines in the 1100 series were great, except in the 1085 which were bad to blow head gaskets due to a lack of bolts. Once Massey switched over to those square cab 2000 series tractors they started having problems due to bad parts in the 24 speed power shift transmission. The 2000 series were still equipped with the reliable Perkins engines but had ALOT of problems with the transmissions. The seals need replacing every couple of years in the powershift transmission. From personal experience I have found that pound for pound the 135 massey ferguson is an extremely strong tractor and gives very few problems. It also has a fantastic draft control for cultivating and moldboard plowing operations.
My 1964 MF-135 diesel is the Deluxe model with MultiPower (changes the 6F/2R tranny into a 12F/4R). My MP is acting up. I probably will have to split the tractor to fix it along with the clutch pack (the pto clutch is not engaging properly). Just a heads up if you're thinking about 1960s MF tractors.
I think that long became farmtrac sometime in the late 90's, before that they used to sell a Romanian tractor. I found a 4wd 610 long a few years ago that I put a deposit on and when I went to pick it up the seller said he was keeping it. I later found that he got asking price.
We still have a dealer up the road that sold long and then farmtrac and now you guessed it, he's a LS dealer. Not sure how supplies are for getting long parts though.
   / Farm tractor models to avoid #38
I would avoid the Ford Jubilee. In their rush to get an overhead valve engine, they took a step backwards in fuel economy and power/weight ratio from the later, flat-head 8n's. Also, this, Ford's first attempt at live hydraulics, was problematic and it is tough to find a Jubilee today with properly functioning hydraulics. Eventially they figured it out and the later 600-800 series tractors were ok. The n's were the last tractors designed while Henry was alive, and no Ford tractor designed since his passing has so dominated the competition. I was never real fond of the gas Ford 3000's, and it seemed my Ford diesel 2000 had more power on both the drawbar and pto, and was way less thirsty on fuel. I have owned Fords, Allis Chalmers, IH, and JD tractors. Of these, I have only had bad experiences with Fords, but also some of the best (on tractors designed prior to 1952). One thing I have always avoided is tractors manufactured or assembled overseas or by a foreign-owned company. That pretty much leaves me with just one choice when it comes to new tractors. Luckily there are still lots of good used ones out there.
   / Farm tractor models to avoid #39
Is there any tractor entirely made in the USA ?? I always thought John deere was but i was wrong.
   / Farm tractor models to avoid #40
I doubt any are entirely made in USA, but JD is about as close as you can get. The 4000 series CUT's are assembled in GA and use a North-American JD Powertech engine. As far as I know, the company has never had foreign ownership.
2018 John Deere 1445 72in Front Mower (A48082)
2018 John Deere...
2025 LandHonor LHR-EW20000 20,000lb Electric Cable Winch (A49461)
2025 LandHonor...
2006 TRAIL MASTER  DETROIT-TRIPLEX PUMP TRAILER (A50854)
2006 TRAIL MASTER...
2019 Ford Fusion SEL Sedan (A50324)
2019 Ford Fusion...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2000 Ford F-450 11ft Flatbed Truck (A49461)
2000 Ford F-450...
