farm pro hard to srart---update
   / farm pro hard to srart---update #1
frigman
oxford ohio
farm pro 2425
wanted to very much thank the people here for helping me trouble shoot my hard starting tractor. turns out that the H position on the start switch is not making contact. If I hold the switch just past the H mark I see that I,m pulling a 30 amp draw . Hold ot for a 10 count,decompress it and BAM---it fired right up. Thanks to all for your help
   / farm pro hard to srart---update #2
The stock Jinma switches are not the highest quality. Mine was delivered new with a bad/intermittent "ON" position.
There is a direct bolt on replacement off a Ford tractor that should be more reliable. I had a replacement switch under warranty in 24 hours so I installed that. If that switch should fail, I will install the ford switch.
Here is a link to John's Jinma site that has information on the modification. The modification of the starter switch is called "Switch Mod(MS word)"
http://www.johnstractor.homestead.com/JinmaInfo2.html
   / farm pro hard to srart---update #3
I think all the dealers should change out the starter switches with the Ford replacement before selling the jinma 200 series. Don't know if the other models use the same Ford replacement or not..The switch costs around $20.00 and alleviates a lot of future problems. Much heavier duty, more water resistant and more reliable.
   / farm pro hard to srart---update #4
<font color="blue"> If I hold the switch just past the H mark I see that I,m pulling a 30 amp draw . Hold it for a 10 count, decompress it and BAM---it fired right up. </font>
Hey FrigMan,
Now you all listen to this fellow!!!!
Spring has Sprung down here, so Crank'm Up!!!! /forums/images/graemlins/smile.gif
Have a nice day,
Joe /forums/images/graemlins/cool.gif
2015 Ford F-350 Utility Flatbed Truck (A51691)
2015 Ford F-350...
2015 Ford Taurus AWD Sedan (A51694)
2015 Ford Taurus...
2003 Walk-Behind Automatic Seed Spreader (A51691)
2003 Walk-Behind...
Valvoline 6 cases manual transmission oil plus 11 (A53117)
Valvoline 6 cases...
2008 Chevrolet Express 2500 Ambulance (A51692)
2008 Chevrolet...
100' Roll of new 5/8"/16mm Crane Cable  (A52384)
100' Roll of new...
