Farm pro 7040
/ Farm pro 7040 #1
Chris-in-wise
Farm pro 7040
I’m looking at buying a used farm pro 7040
The guy says it runs great but has a small hydraulic leak in the back. I asked if it was a hose and he said it’s from the control bank and that it was an easy repair with a gasket. I’ve never owned a tractor but am at a point where I need one. It will be on a smaller farm so won’t be used heavily or abused. Can I get parts easily, and are they easy to repair if need be. Also how serious is a hydraulic leak at the bank?
/ Farm pro 7040 #2
Love it when someone is selling something with an obvious problem and say it is a very easy fix. If it is an easy fix why not fix it before you sell it.
I would walk away. No telling what else is wrong with it.
/ Farm pro 7040 #3
Treat that thing like the PLAGUE
The general problems with those little Chineese tractors are broken castings & leaking oil all over
willy
/ Farm pro 7040 #4
willy
Little compared to what ?
It's front tires are larger than the YT 235C REAR tires.
The 7040 has a base weight of 7000lb before adding the FEL
It is powered by a 70 HP Perkins diesel.
Perkins
turbocharged diesel
4-cylinder
liquid-cooled
Displacement: 243.798 ci
4.0 L
Bore/Stroke: 3.94x5.00 inches
100 x 127 mm
Power: 70 hp
52.2 kW
Rated RPM: 2200
Oil capacity: 17.96 qts
17.0 L
Coolant capacity: 15.84 qts
15.0 L
/ Farm pro 7040
This guy buys and sells tractors and I don’t believe he tries to repair anything.
/ Farm pro 7040
Is that a good diesel engine? It is a big tractor but for the price he is asking, if it’s a simple fix would be worth it.
/ Farm pro 7040 #7
Yes Perkins makes Very Good diesel engines.
They have been at it for a Very Long time. They actually helped Ford design the World tractor series 2000-6000 engines in the early 1960's which are also long lived engines.
Massey Ferguson has used Perkins diesels in some of their tractors as well.
I would call Affordable and Circle G and ask how parts availability is for that model.
That is a lot of tractor that can easily handle Cat 2 implements.
PS if it is equipped with a Koyker loader ( USA) that is a bonus, they are very good FEL's
I have pushed the one on my chinese tractor very hard and it has held up well.
Another parts and info source might be Keno tractors as well.
/ Farm pro 7040
Thanks for that info. I will call those 2 places and check on parts availability
/ Farm pro 7040
Thanks for that info, it does have a Koyker FEL on it. I did call all of those places and none of them sell parts for tractors over 40hp anymore. They would have to be sourced from china and it’s a 3 month wait for even the simple things such as air,oil and fuel filters. It was suggested by several of those dealerships to pass on the tractor.
/ Farm pro 7040 #10
Parts are getting harder to source since everything went to tier 4 especially with the china tractors.
I would heed their advice, because parts availability is no small thing.
If you don't mind me asking what is the asking price? Is it a cabbed tractor? How many hours on it?
/ Farm pro 7040
Sure, it’s a cabbed tractor but it was missing all the glass except the windshield and didn’t have the doors. I didn’t care about that stuff. Asking price was $6000 not sure on hours.
/ Farm pro 7040 #12
2008 Freightliner Allegro Bay Class A Motorhome (A61574)
2008 Freightliner...
New/Unused Mini Quick Attach Pallet Forks (A65583)
New/Unused Mini...
2015 John Deere 8270R (A64119)
2015 John Deere...
Rotary Auger Motor Attachment (A61572)
Rotary Auger Motor...
2014 Dynapac CP142 9 Wheel Pneumatic Roller (A62679)
2014 Dynapac CP142...
7ft Fork Extensions (A61572)
7ft Fork...
