Farm Pro 2430 Compression
   / Farm Pro 2430 Compression #1
Nitric
02 Farm pro 2430
Anyone know what the compression should be on jinma/farm pro 2430 tractor? Can't seem to find any good data on it online.
   / Farm Pro 2430 Compression #2
Approximately 18:1 ratio. You don't want more than 20 psi differential between cylinders. If you want the actual pressure reading you can get it by calculating..........
Or, just get a Harbor Freight diesel engine compression tester.
CHALLENGER VACUUM PUMPS (3) (A50854)
CHALLENGER VACUUM...
4 BRIDGESTONE 11R24.5 (A50854)
4 BRIDGESTONE...
100GAL L SHAPED FUEL TANK (A50854)
100GAL L SHAPED...
Oil Well Pump Jack with Motor (A49461)
Oil Well Pump Jack...
100 GAL FUEL TANK (A50854)
100 GAL FUEL TANK...
UNKNOWN 16 T/A UTILITY TRAILER (A50854)
UNKNOWN 16 T/A...
