Nov 29, 2021 / Farm Pro 2430 Compression #1 N Nitric New member Joined Nov 21, 2021 Messages 7 Tractor 02 Farm pro 2430 Anyone know what the compression should be on jinma/farm pro 2430 tractor? Can't seem to find any good data on it online.
Nov 29, 2021 / Farm Pro 2430 Compression #2 B Bob Rooks Elite Member Joined Feb 27, 2007 Messages 3,895 Location Washington state Tractor Yuchai Dozer (sold). Approximately 18:1 ratio. You don't want more than 20 psi differential between cylinders. If you want the actual pressure reading you can get it by calculating.......... Or, just get a Harbor Freight diesel engine compression tester.
Nov 29, 2021 / Farm Pro 2430 Compression #3 T thepumpguysc Elite Member Joined Apr 14, 2010 Messages 3,782 Location South Carolina Tractor Injection Pump Rebuilder Anything OVER 300psi is considered good/ok..
Nov 29, 2021 / Farm Pro 2430 Compression #4 B Bob Rooks Elite Member Joined Feb 27, 2007 Messages 3,895 Location Washington state Tractor Yuchai Dozer (sold). thepumpguysc said: Anything OVER 300psi is considered good/ok.. Click to expand... Yes and no. If one is 300 psi and another is 350 psi, not good.
Nov 29, 2021 / Farm Pro 2430 Compression #5 T thepumpguysc Elite Member Joined Apr 14, 2010 Messages 3,782 Location South Carolina Tractor Injection Pump Rebuilder True..
