Farm Pro 2425 wont throttle up
   / Farm Pro 2425 wont throttle up #1
to_southern
Hello all,I bought a 2002 Farm Pro 2425 with 71 hrs. it will idle but that is all. Will not throttle up.Thanks for any help.
   / Farm Pro 2425 wont throttle up #2
Your tractor is a re-badged Jinma 254. If it will start and run first thing I would do is go to the left side of the engine as you set on in and move the throttle linkage by hand on the injector pump. If this allows it to throttle up you need to follow the linkages back to the foot throttle and the hand throttle to see the issue.
Also the injector pump has its own lube oil reservoir. It holds about 20 oz and is not shared with the main engine oil reservoir. I change mine every 100 hours and do my engine oil every 50 hours so every other oil change. Have you ever changed yours? If not you may have destroyed the pump.
I will ask the moderators to move this to the Chinese Tractor section so you can get some real help. You will have much better luck.
Also either fill out your profile or put in your city and state so we can get you the nearest help.
Chris
Thanks as soon as i try i will let you know
Thank you bob i will check it out
JOHN DEERE 8R 280 (A53084)
JOHN DEERE 8R 280...
Year: 2012 Make: Honda Model: Accord Vehicle Type: Passenger Car Mileage: 91,438 Plate: Body Type... (A51694)
Year: 2012 Make...
JOHN DEERE XUV590M (A53084)
JOHN DEERE XUV590M...
2014 Ag Spray Schaben Sidedresser (A52748)
2014 Ag Spray...
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
John Deere WG48A 48in Walk-Behind Mower (A51691)
John Deere WG48A...
