farm pro 2425 hose help please
   / farm pro 2425 hose help please #1
ymurf
I have a Farm Pro 2425 and when i lift the 3 point with my brush hog hooked up I have a hydraulic leak. On the right side under the seat(the right side as your sitting on tractor) there is a hose which i believe they call a banjo fitting on the end.It has a bolt going through it and hydraulic fluid leaks a pretty good drip from there when i lift the 3 point.Do these have o-rings in them or do i replace the whole hose?Any help would be greatly appreciated..
   / farm pro 2425 hose help please #2
They have rubberized washers between the banjo fitting and whatever it's mated to (hydraulics too). You can get OE replacements for them (50-75 cents each maybe) from Jinma/FarmPro/NorTrac/et cetera. The OE however are not suitable for more than one-time use. Aftermarket equivalents are more expensive ($1.50-$2.00 each). Some dealers have them, as do most Japanese and European motorcycle shops
//greg//
   / farm pro 2425 hose help please #3
   / farm pro 2425 hose help please #4
Have you tried to tighten the bolt up at all?
Sometimes that's all it takes with those banjo bolts to compress the seal a little more.
   / farm pro 2425 hose help please #5
Rob makes an excellent point. On my 454, one of the steering hose banjos persistently weeped on the cylinder. I was initially afraid of overtightening, for fear of crushing the fitting. But out of frustration, I put a torque wrench on the thing and tightened a few pounds at a time. I was pleased to realize that the leak had stopped by the time I'd applied only 65 ft-lbs
//greg//
EZGO GOLF CART (A50323)
EZGO GOLF CART...
2014 Ford Escape (A50324)
2014 Ford Escape...
NEW Mini Excavator Fixed Thumb Attachment (A53002)
NEW Mini Excavator...
2017 TOYOTA TUNDRA (A52472)
2017 TOYOTA TUNDRA...
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50775)
PLEASE CHECK...
2024 KMC 7406 (A53084)
