farm pro 2425 hose help please
   / farm pro 2425 hose help please #1
ymurf
Bronze Member
I have a Farm Pro 2425 and when i lift the 3 point with my brush hog hooked up I have a hydraulic leak. On the right side under the seat(the right side as your sitting on tractor) there is a hose which i believe they call a banjo fitting on the end.It has a bolt going through it and hydraulic fluid leaks a pretty good drip from there when i lift the 3 point.Do these have o-rings in them or do i replace the whole hose?Any help would be greatly appreciated..
   / farm pro 2425 hose help please #2
They have rubberized washers between the banjo fitting and whatever it's mated to (hydraulics too). You can get OE replacements for them (50-75 cents each maybe) from Jinma/FarmPro/NorTrac/et cetera. The OE however are not suitable for more than one-time use. Aftermarket equivalents are more expensive ($1.50-$2.00 each). Some dealers have them, as do most Japanese and European motorcycle shops
//greg//
   / farm pro 2425 hose help please #3
   / farm pro 2425 hose help please #4
Have you tried to tighten the bolt up at all?
Sometimes that's all it takes with those banjo bolts to compress the seal a little more.
   / farm pro 2425 hose help please #5
Rob makes an excellent point. On my 454, one of the steering hose banjos persistently weeped on the cylinder. I was initially afraid of overtightening, for fear of crushing the fitting. But out of frustration, I put a torque wrench on the thing and tightened a few pounds at a time. I was pleased to realize that the leak had stopped by the time I'd applied only 65 ft-lbs
//greg//
Mini Excavator Attachment Set (A50121)
Mini Excavator...
Truck Flatbed (A50121)
43030 (A51691)
43030 (A51691)
Marliss Industries Grain and Soybean Drill - Selling ABSOLUTE NO RESERVE (A52748)
Marliss Industries...
2012 KOMATSU GD655-5 (A52472)
2012 KOMATSU...
