Farm Pro 2425 Fluid Problem
/ Farm Pro 2425 Fluid Problem #1
Jdar
I have a Farm Pro 2425. I was using it on Saturday and fluid started spraying out from under the steering wheel. I believe it's hydraulic fluid. Has any one had this happen, or know how to fix it. The hoses are all tight.:D
/ Farm Pro 2425 Fluid Problem #2
So the it's not leaking where the hoses are tight? Or not?
Can you tell where it IS leaking? Look under the dash...wear safety goggles and try to see where the leak is coming from exactly. It's got to be your hydraulic power steering box OR the seals where the steering column shaft enters it.
/ Farm Pro 2425 Fluid Problem #3
If I remember correctly, at the very bottom of the steering box is a plate - fastened with a gasket and half a dozen or so hex bolts. I recall having to tighten several of those bolts to stop a significant drip in that location
//greg//
Thanks guys, I'll try both this weekend.
2017 Volvo VNL T/A Sleeper Cab Truck Tractor (A64556)
2017 Volvo VNL T/A...
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A64556)
2022 Peterbilt 567...
Wooden Plant Holder (A64557)
Wooden Plant...
2022 EZ-GO ELITE...
2015 Ford F-450 4x4 Crew Cab Utility Flatbed Truck (A64556)
2015 Ford F-450...
KUBOTA Z121S KOMMANDER ZERO TRUN MOWER (A65054)
KUBOTA Z121S...
