Farm Pro 2425 Fluid Problem
   / Farm Pro 2425 Fluid Problem #1
Jdar
I have a Farm Pro 2425. I was using it on Saturday and fluid started spraying out from under the steering wheel. I believe it's hydraulic fluid. Has any one had this happen, or know how to fix it. The hoses are all tight.:D
   / Farm Pro 2425 Fluid Problem #2
So the it's not leaking where the hoses are tight? Or not?
Can you tell where it IS leaking? Look under the dash...wear safety goggles and try to see where the leak is coming from exactly. It's got to be your hydraulic power steering box OR the seals where the steering column shaft enters it.
   / Farm Pro 2425 Fluid Problem #3
If I remember correctly, at the very bottom of the steering box is a plate - fastened with a gasket and half a dozen or so hex bolts. I recall having to tighten several of those bolts to stop a significant drip in that location
//greg//
Thanks guys, I'll try both this weekend.
2011 TRAIL KING LOWBOY TRAILER (A50459)
2011 TRAIL KING...
2015 KENWORTH T800 MID-ROOF SLEEPER (A50854)
2015 KENWORTH T800...
2025 8ft Office Shipping Container (A49346)
2025 8ft Office...
2011 GR TRAILER GOOSENECK (A50854)
2011 GR TRAILER...
1996 COUNTRY COACH INTRIGUE 40FT RV (A51222)
1996 COUNTRY COACH...
Komatsu D39PX-24 Crawler Tractor Dozer (A49346)
Komatsu D39PX-24...
