FARM PRO 2420
/ FARM PRO 2420 #1
jerm47250
I HAVE A FARM PRO 2420 AND IT WILL START UP AND RUN AT AN IDLE BUT WHEN U HOLD THE THROTTLE WIDE OPEN IT ACTS LIKE IT RUNS OUT OF GAS THEN IF YOU PUMP THE BLEEDER PUMP A COUPLE OF TIMES IT WILL START RIGHT BACK UP. IT ONLY HAS 50 HOURS ON IT IF ANYONE COULD KNOW WHAT MIGHT BE WRONG I WOULD APPRECIATE IT.
/ FARM PRO 2420 #2
Shut off the fuel at the sediment bowl, then remove the fuel line between there and the fuel pump. There will likely be an inline screen at the fuel pump end. Clean it. Reinstall. If the problem persists, check the other flexible hoses for a similar screen.
//greg//
1761 (A58375)
1761 (A58375)
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
2025 78in. Hydraulic Dual Cylinder Rock Grapple Skid Steer Attachment (A61572)
2025 78in...
2021 CATERPILLAR 299D3 SKID STEER (A64279)
2021 CATERPILLAR...
445 (A63290)
445 (A63290)
2022 Belshe WB14 18ft Trailer (A64047)
2022 Belshe WB14...
