Farm Pro 2420 torque specs
   / Farm Pro 2420 torque specs #1
bigcountry1009
Clinton, SC
Farm Pro 2420
Time to finally fix my little 2420. It's been languishing around for longer than I'd care to admit. Fairly certain it's the head gasket. Got water in oil. Found out I had leak somewhere behind the thermostat that pushed most of the water out. Also found out that the trusty temp guage wasn't guaging much at all, so I ran it. didn't really push it hard, but did notice white smoke when I shut it down. Ran fine when I parked it, drained the oil and it had that milky gray color to it. It hadn't been that way long, I hadn't been a few weeks changed the oil and filter and it was fine then, so I hope I didn't do much damage. I have the manuals for it. The drawings and parts lists are pretty self explanatory, however they do leave something to be desired. I have the ones in Chinese too, but I can't quite translate them. Problem is I can't find any torque specs for when I put the motor back together. Any suggestions? Thanks ahead of time.
Also, anyone know where I can get a better price on parts than the Homier or Jinma websites?
   / Farm Pro 2420 torque specs #2
The torque specs in the manuals are metric anyway, you'd probably have to convert them. I'm on the road now with my laptop, my books are at home. But if you don't get the torque and the headbolt sequence by then, I'll look them up. You should adjust valve lash and decompression while the valve cover is off as well.
JMParts and Homier prices are pretty representative. Overall, most of the dealers price their parts reasonably close. You might find an item or two cheaper at one dealer or another, but in the long run - just pick one you have good luck with, and stick with him. Check the dealer section of this and other Chinese tractor forums for contact info
//greg//
   / Farm Pro 2420 torque specs #3
Like Greg said the parts price are all about the same but Tommy at Affordable Tractors has always had what I wanted and the shipping is fast and cheap.
Chris
   / Farm Pro 2420 torque specs #4
Ok, back home now. Before I dig out the specs, I need to confirm that yours has the YangDong Y380 engine.
//greg//
   / Farm Pro 2420 torque specs #5
I just ordered a bunch of parts from Tommy at Affordable. I am no pro, had no numbers to give him, he did all the research just from my description. To me, thats good service.
   / Farm Pro 2420 torque specs #6
NEW Wolverine 72'' Skid Steer Tiller (A53002)
NEW Wolverine 72''...
Quick Attach Skid Steer Plate (A51573)
Quick Attach Skid...
1988 Ford F-250 Pickup Truck, VIN # 1FTEF26N1JNA71750 (A51572)
1988 Ford F-250...
2014 PETERBILT 579 SLEEPER (A52576)
2014 PETERBILT 579...
