farm pro 2420 shuts off
   / farm pro 2420 shuts off #1
mazdaman38
CASTALIA,NC
farm pro 2420
Hello folks I'm new to the site and have recently acquired a 2004 farm pro 2420 and have some problems. First,is it starts up and runs fine with no smoke at all of any kind and after about 30-45 mins it shuts off like I pulled the shutoff knob. Second is in that 30-45 mins it gets over the 80 mark on the temp gauge. So my real question is if the head gasket is blown or head is cracked will it cause it to do this because it never looses prime or starves for fuel thanks for any help I may receives, John
   / farm pro 2420 shuts off #2
On my 04 Jinma, the only way the engine stops is by cutting off the fuel. Normally, the only way to do this is the shutoff knob. But if you are not diligent about only using clean fuel then the numerous fine screens in the fuel line can clog up very quickly. I think that my Jinma had one in the tank, one at the bowl, and there was a third that I can not remember where. A few years ago, I removed the tank and bowl screens because they were such a pain to get to and installed an inline filter between the tank and bowl. This filter can be changed in just a couple of minutes with little more than pliers. Find the third screen and just clean it.
I think that if you had a problem with the head or gasket you would have much more severe symptoms than a slight rise in temp. You would probably get exhaust in your cooling system that would cause boil overs, or might see antifreeze in your oil. Check the oil and antifreeze levels, but don't panic if the are just a little off. My Jinma will reach close to 100 when I am working it hard. Thermostats can go bad and is an easy replacement for under $10 from NAPA. I would start there. My original thermostat broke at the arch that the expanding pellet pushes against. Overall, my Jinma is a darn hard working machine that takes a licking and keeps on ticking.
   / farm pro 2420 shuts off #3
There's also a filter Cartridge unless it's been replaced with the spin on type. My 2004-2425 had the spin on type and I believe a screen where line goes into injector pump.
   / farm pro 2420 shuts off #4
2017 SANY SY365C LC EXCAVATOR (A51246)
2017 SANY SY365C...
2013 Chevrolet Malibu Sedan (A51694)
2013 Chevrolet...
UNUSED INDUSTRIAS AMERICA 12F HYD LAND LEVELER (A51247)
UNUSED INDUSTRIAS...
UNUSED AGT MXCRT23 STAND ON SKID STEER (A51247)
UNUSED AGT MXCRT23...
2019 Chevrolet Tahoe LT SUV (A51694)
2019 Chevrolet...
2015 Peterbilt 320 Garbage Truck (A52377)
2015 Peterbilt 320...
