FARM KING SNOWBLOWER
/ FARM KING SNOWBLOWER #1
mlange2009
Bronze Member
SAW a snowblower 3 point mount,it has wheels on each side,i'm confused wheels insted of skid plates?????
/ FARM KING SNOWBLOWER #2
could be a custom design for a gravel driveway, or possibly a dealer installed item for the gravel driveway use. Having well over 1800 foot gravel driveway I can tell you I wish new Holland design wheels for mine do have pictures of it?
no pics sorry,just thought wheels would freeze up,never saw that before,so some do have wheels?
/ FARM KING SNOWBLOWER #4
The wheels are added by the end user or the shop that sold the snow caster.
You can find great pnuematic swiveling caster wheels with ball bearings at Mcmaster.com
All that is needed is some angle iron and a drill for mounting the angle iron.
You need to purchase nylock nuts or use loctite to be be sure nothing vibrates loose when you attach everything to the snow caster housing.
The wheels prevent the corners of the snow caster from digging into soft ground and allow easier turns with less wieght on the snow caster whether in front or in the rear.
The4 skids can be left on the snow caster if desired as the tires usually keep the snow caster less than an inch above the ground when working.
2012 FORD FOCUS SEL (A65054)
2012 FORD FOCUS...
NEW Wolverine 66" Skid Steer Bucket, 38" Depth (A62679)
NEW Wolverine 66"...
2014 F-150 4WD (A63689)
2014 F-150 4WD...
2015 ABU TRAILER 14 FOOT UTILITY TRAILER (A65643)
2015 ABU TRAILER...
3'x8' Stack of Sheet Metal (A64127)
3'x8' Stack of...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
