farm king mower issue
   / farm king mower issue #1
laurencen
Veteran Member
saskatchewan Canada
Bobcat Toolcat 5600T Kioti CK20, Cat D2 dozer, Cat 420 tractor loader, Deer 644E loader, Bobcat E32 mini and Bobcat 590 skidsteer, Toro Groundsmaster 325D
Well finaly got the grass and weeds down on my field, having issues with the nower, after a hour of cutting the blades litrally stall, taking a look underneath the underside of the deck is full of pacled cuttings like mud, it is stopping the blades turning, I have hit many rocks while cutting but the blades are not that bad, it is very hard packed but will come off with a putty knife, is this normal, could it be the crop material I cut down
Thanks in advance for any ideas
   / farm king mower issue #2
Clean it up good and then spray some silicone lube under there.
Are you running at correct pto speed? discharge chute open?
soundguy
   / farm king mower issue #3
Is it a Farm King finish mower or bush hog style rotary cutter? I would expect the packed material on a finish mower but not the rotary cutter. I'd also check to be sure the blades are on right, and not installed upside down.
   / farm king mower issue #4
i used to have the same problem with my 84" farm king, i painted the underside of the mower with slip plate, i also suggest spraying with silicone before mowing
thanks for the ideas, the blades are on correctly, cleaned it up and it still sticks, not as bad but eventually the blades jam into the packed material on the sides, I will try sharpening them today and try again
Laurence
1985 Eager Beaver 9D0W Tri-axle Flatbed Equipment Trailer (A50322)
1985 Eager Beaver...
UNUSED (2) 3500# DROP AXLE W/ BRAKES (A54756)
UNUSED (2) 3500#...
2015 Ford F-450 Crew Cab Knapheide Service Truck (A53422)
2015 Ford F-450...
2015 Ford Taurus SE Sedan (A51694)
2015 Ford Taurus...
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A55787)
2025 Kivel Forks...
2019 FORD F-250 XL CREW CAB SERVICE TRUCK (A54756)
2019 FORD F-250 XL...
