FARM JACK FOR TREE PUSHER
   / FARM JACK FOR TREE PUSHER #12
If you have kids, buy a rope 4 times the length of your highest tree and have them pull over the tree. That way you always know where they are while you are cutting AND know for sure they are out of the danger zone. Make them feel involved and important and tell them the truth when they are 20, it will make for a big laugh. (thats what my father did).
I'll remember that one, my 3 year old nephew is just big enough to escape from parental observation, and to check out on grandpa or uncle in the shop.... :)
By they way, i've also seen professional landscape loggers fell trees with a sort of crowbar that fitted precisely into the chainsaw cut, while sawing the other guy held pressure with one arm: When he felt the tree was releasing, he would tap the other man holding the chainsaw, on the shoulder to warn him, and then tumble the tree with both arms on the crowbar.
   / FARM JACK FOR TREE PUSHER #13
If you do build a jack always always watch for rotten spots in the wood. If you cut a notch for you jack and start lifting on the wood if the tree is rotten you could have the jack pop out at you. Or the tree could rock backwards and fall the wrong way.
I use plenty of plastic wedges to force the tree over. When they get to be large and weighted with branches in the wrong direction is a good time for the tree jack.
   / FARM JACK FOR TREE PUSHER #15
I think I'll stick with a cable/rope and snatch block to pull the tree where I want it. That is if I can't get the bucket up against it to push.....
   / FARM JACK FOR TREE PUSHER #16
One remark on snatch blocks, winches and pulleys to pull over trees..
Too much tension will stimulate barberchair and or other surprises.
Point of pulling a tree over is to guide it, not to force it. Your notch and backcut are there to give the direction.
Stay safe.
Oh and about the bucket,... i always put one of my pallet forks on the bucket to push, so i am at safe distance from the tree....:eek::p
   / FARM JACK FOR TREE PUSHER #17
I am not a logger and dont live in an area of to much big timber but i have had to clean up after a few storms including a few ice storms. One thing I think people do not realize is the amount of weight your are dealing with when cutting trees. I fell a couple trees in a tight spot next to a house last weekend, my buddy was just dying to use a newly bought rope and his "massive 700cc 4 wheeler". I explained the weight issue to him but he still wanted to use it to pull over the tree as I cut. I had the tree chained to the base of another tree 60' away and used a come-a-long to pull the slack out of the chain and get the tree pointed in the right direction. He tied the rope off in the tree and tied it to the 4wheeler's rack on the back. Well the tree fell twords my chain as desined but he was pulling at about 45 degrees and was amazed at how it jerked him back, bent the rack, and snaped the rope. I just laughed and said "told ya so city boy".
be careful!!! I thought I was "the man" when cutting trees until I had a limb barber chair and catch my mouth, took about 15 stiches and a couple hours in the er to get over that.
   / FARM JACK FOR TREE PUSHER #18
Good point workingallthetime. The guy is lucky the rope didn't snap him alongside the head.. Sorry about the branch whacking you. That had to hurt.. I've had enough near misses with branches and tree's that I try to respect them all. I do use ropes to pull but they are set well above the 50% height of the tree to take advantage of leverage. If my ropes are in doubt I toss them.
   / FARM JACK FOR TREE PUSHER #19
I have to agree with others a cable is MUCH{MUCH} safer!!! When pushing on a tree with a jack there is no real way to make sure the jack stays in place. What happens if the trees starts to go where you want then comes a gust of wind, the jack won't help{wind happens} cable would stay in place if done proper. I have been cutting down trees for 30+ yrs and have used cables to other trees to large trucks and other large machinery never had a problem. I have also had the perfect tree going exactly where it was suppose to only to have a freak gust of wind come up and spin it like a top, destroying a chain saw. I also believe there is no such thing as a professional tree cutter only those that are willing to learn each day they big up a saw.
   / FARM JACK FOR TREE PUSHER #20
I welded up a treepusher this winter(I call it a TimberJackit) .
I haven't tried it out yet, but hope to this weekend .
Basically it is a steel rectangular tubing(Jacket:)) that slips over a 48" Jackall Jack(that most half ton trucks in this area carry).
If anyone is interested I'll see if I can download a picture this weekend .
I am cutting a shooting lane about 300 yds long through my son's heavy timber(poplar,Jack Pine, Spruce) and some of the trees are not co-operating ....I'm trying to drop them on the trail behind me as I go along .
Wedges work fairly well, but gotta keep an eye on the dead limbs high up in those old Poplars, when pounding in the wedges .
I think that the TimberJackit will be safer in that regard .
PALLET TOTE OF MISC PARTS (A58374)
PALLET TOTE OF...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
(2) 12.4-24 TIRES W/ 8 LUG RIMS (A58374)
(2) 12.4-24 TIRES...
12V 20GPM Gasoline Fuel Transfer Pump (New/Unused) (A59225)
12V 20GPM Gasoline...
Adams 6 Ton Fertilizer Spreader (A56435)
Adams 6 Ton...
