Price Check Fair BX2200 price?
   / Fair BX2200 price? #1
woodchuckc
Tennessee
Kubota L5030
A guy I know has a BX2200 (4 years old, I believe) that he would like to sell. It has a 54" MMM, but no FEL. He has only used it to cut his grass and pull an aerator over his 1/2 acre yard, and it has a grand total of 72 hours on it. He is asking $ 6500 for it, and is firm on that price. Does this sound like a reasonable deal? I have only dealt with larger tractors, and don't have a good feel of how these small CUTs hold their value.
I would like to end up with a FEL for it if I do buy it; did / does Kubota make a quick detach FEL for it? I assume that it is pretty pricey ($2500 - $3000 ???). I would also like to trade in the 54" MMM for a 60" one, since I have about 3 1/2 acres of yard to mow.
Thanks for the comments / feedback!
-Chuck
   / Fair BX2200 price? #2
I suggest that you look around for a unit that comes with the major attachments that you need. Buying a FEL and MMM separately is usually tedious and a lot more expensive.
   / Fair BX2200 price? #3
My FEL model LA211 for the 2200 was about $2200 (installed with the new tractor). I think there are some aftermarket loaders for the 2200.
I think an FEL for the BX22 and maybe the BX23 might fit the 2200. When they went to the 24 and 2350 (hope I have this right), they changed the FEL so the valve stays with the tractor on the later models. On the 2200, the valve comes off with the FEL. I don't know if the mountings changed with the newer models.
Yes, it's quick attach. Takes less than five minutes to install/remove, if you do it on hard/level ground.
When I got mine, the 54" MMM was about $250 less than the 60". You might find someone that wants to trade MMM. I needed 54" for gate clearance.
Hope this helps.
Ron
2015 DRAGON 137BBL DOUBLE CONICAL VACUUM TRAILER (A52472)
2015 DRAGON 137BBL...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
Tandem Axle Rear...
New Wolverine Skid Steer 3pt Hitch Quick Connect (A53002)
New Wolverine Skid...
