Failed Lug/Stud
   / Failed Lug/Stud #1
ThisldooFarm
Upstate NY
B7800
B7800. I was changing the front wheels. One of the six studs/lugs came off with the nut intact. The hub threads were stripped. I suspect this happened during initial intalllation. What to do? They appear to be threaded the same as the nuts. Is there a retrofit splined lug? Retap with larger lug? Ignore and just use the remaining 5 lugs until one of these fails? Any help would be apprecieated. Thanks again.
   / Failed Lug/Stud #2
You could try repairing the threads with a thread repair kit or buy a replacement hub.
   / Failed Lug/Stud #3
Heli coil kit/ thread repair kit would be cheaper and easier to install than anything else.
   / Failed Lug/Stud
Great idea. Do they make them in metric? Any idea where to get? NAPA?
Thanks.
   / Failed Lug/Stud #5
Yes they make them in metric and NAPA does sell them. I'm not sure if they will have the size you need but they can probably order it for you if they don't.
Swamp Buggy (A49346)
2014 Kia Sedona Van (A50324)
2014 Kia Sedona...
2014 GMC ACADIA SUV (A51222)
2014 GMC ACADIA...
2019 FREIGHTLINER SPRINTER 2500 (A51219)
2019 FREIGHTLINER...
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A50459)
2007 FORD F-750XL...
2015 KOMATSU PC170LC-10 EXCAVATOR (A50458)
2015 KOMATSU...
