sd455dan
Elite Member
- Joined
- Oct 23, 2012
- Messages
- 4,792
- Location
- North Idaho
- Tractor
- Rhino 554, Ford 550 TLB (JD X500, MTD, Gilson riding mowers) Ford 3000-Sold
Well after 30 years of use guess it was inevitable.
The Rhino 554 front axle needs attention
Seal seems to have failed on the left outer bearing hub.
It is a hybrid design, because the outer main hub shaft bearing can be greased from center of the wheel hub.
The rest of the axle pivots can also be greased but also contain hydraulic oil.
Was moving 3 large pieces of a leaner tree I dropped and was carrying using the grapple.
Noticed Grease and fluid mixed drooling around the wheel. O joy
Lifted the front end using the FEL and everything is smooth and no bearing play or roughness so hope a seal replacement will take care of the drooling.
May as well change the front axle oil as well. been a few years since I changed it as well using universal tractor fluid for oil.
post pics soon.
Well still need the tractor Had a widow maker right over the driveway entrance to tall to get close to ,
thought about cutting the butt
but it might have slid back towards the ladder.
Finally hooked on the lower end and pulled towards the road where it did drop the butt then cross cut it about 5 feet up and pulled again after resetting the chain then drug the main piece to the burn pile
post pics soon.
