Factory gooseneck Hitch or B&W turnoverball?
   / Factory gooseneck Hitch or B&W turnoverball? #1
Wnc3
S.E., Texas
John Deere 820 utility, John Deere 5525, 997 JD Zmower, Komatsu PC 35 miniExcavator
I had the B&W setup in a Ram 2500 , 2006 and liked it.
Now I have a 2014 F250 that does not have the GN factory hitch ( I think it is a Reese) and wish it did.
That said, do I install the B&W or go with something else?
Thx
   / Factory gooseneck Hitch or B&W turnoverball? #2
I had the B&W setup in a Ram 2500 , 2006 and liked it. Now I have a 2014 F250 that does not have the GN factory hitch ( I think it is a Reese) and wish it did. That said, do I install the B&W or go with something else? Thx
B&W is a good hitch, probably installed 20 of them. My biggest complaint is the paint stinks.
For that new of a truck I would order the Ford factory hitch.
Chris
   / Factory gooseneck Hitch or B&W turnoverball? #3
B&W.. they also make the fifth wheel adapter that you can remove the ball and put the fifth wheel in the ball socket.
   / Factory gooseneck Hitch or B&W turnoverball? #4
Yes, we have that and I love it since I haul both GNs and a 5th wheel camper.
   / Factory gooseneck Hitch or B&W turnoverball? #5
I have had both the BW in prior F-350s and now the Ford Factory GN in 2012 F-350. I prefer the Ford but would expect it to be much higher cost than the BW.
Sent from my iPad using TractorByNet
   / Factory gooseneck Hitch or B&W turnoverball? #6
If your ordering the truck get the factory, if your adding it to an existing truck go b&w.
Brett
Thanks for the feed back. I forgot about the 5th wheel option.
   / Factory gooseneck Hitch or B&W turnoverball? #8
If you install it yourself I've got the 4" hole saw. I did it by myself in a couple hrs. Even lifted the bed instead of notching the beds pinch weld. If you need a hand give me a hollar
I installed it in several dodges and my current truck which is a '13 F250. If you want air bags too, I've got I set that just sitting since I lifted my truck.
Brett
Thanks, I may take you up on the airbags if I need them.
I already sent the truck to Master Hitch in Houton for the GN.
I hope you got your bed centered up on the back of the cab when you drilled the hole....mine came from the factory crooked and I aligned it.
I have read misaligned beds are fairly common on Fords.
(Maybe the hitch centers it up better when it goes back together)
   / Factory gooseneck Hitch or B&W turnoverball? #10
Brett
Which airbags fit with the B&W in your 250?
UNUSED CFG INDUSTRIAL EXCAVATOR ATTACHMENT SET (A51248)
UNUSED CFG...
UNUSED CFG INDUSTRIAL XZ20R EXCAVATOR (A51247)
UNUSED CFG...
2009 Volvo VHD Tandem Dump Truck, VIN # 4V5KC9EF19N270338 (A51572)
2009 Volvo VHD...
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/slimjaro-vs-burnjaro-reviews-a-comprehensive-analysis-of-benefits-and-1044755
https://www.accessn...
2R S-TINE CULTIVATOR W/ ROLLING BASKETS (A51247)
2R S-TINE...
UNUSED HURRICANE 10' WROUGHT IRON SITE FENCE (A51248)
UNUSED HURRICANE...
