Factors to consider in choosing hydraulic fluid
   / Factors to consider in choosing hydraulic fluid #1
jmfox
Platinum Member
After much research I have found the best crankcase oil and grease for the various fittings on my machine. Now I am wondering what I need to know about tractor fluid. To date I have been using whatever ASV sells.
jmf
   / Factors to consider in choosing hydraulic fluid #2
jmf
I just go by the book.
   / Factors to consider in choosing hydraulic fluid #3
I agree. find one that meets or exceeds the specs stated in your owners manual.. and then service at least are regularly as the manual states.. if in question about the oil.. pull a sample mid year and send it off and see how the oil is doing...
soundguy
   / Factors to consider in choosing hydraulic fluid #4
Typically its UTF, but check the manual.
Definitely tractor fluid. Motor oil and grease get a lot of attention but, except for keeping it clean, it appears tractor fluid is not that important.
jmf
2006 KENWORTH T800 TANDEM SLEEPER TRUCK (A52141)
2006 KENWORTH T800...
(2) METAL SPOOLS W/ SOME DURALINE 4" PVC PIPE (A51248)
(2) METAL SPOOLS...
2020 CAT 239D3 Skid Steer (A51573)
2020 CAT 239D3...
(4) 55 Gallon Drums of Mixed Laundry Detergent and Fabric Softener (A51573)
(4) 55 Gallon...
2015 CATERPILLAR 323FL EXCAVATOR (A51246)
2015 CATERPILLAR...
Mohawk 12,000lb Two-Post Electric Auto Lift (A51691)
Mohawk 12,000lb...
