F935 PTO shaft
/ F935 PTO shaft #1
Aeroeng
Jackso, MI
JD and Oliver
I am replacing the PTO shaft again... and would like to know if anyone has assembled the read bearing in a fixed position. Not using the springs that allow it to float.
/ F935 PTO shaft #2
:welcome: to TBN
Here is a link to jdparts, where you can enter model F935, browse to alphabetic list under PTO and select the parts you are questioning about.
John Deere - Parts Catalog
Hope it helps in posing the question.
/ F935 PTO shaft #3
Could be wrong but I thought the springs are there for setting belt tension, so I would say if still able to set belt tension then yes.
/ F935 PTO shaft #4
What is a "read" bearing? or is this a typo?
2021 TAKEUCHI TB240 EXCAVATOR (A64279)
2021 TAKEUCHI...
2003 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2003 Ford F-150...
6 1/4 INCH OD 90 DEGREE ELBOWS (A63569)
6 1/4 INCH OD 90...
EMGLO PORTABLE AIR COMPRESSOR (A63290)
EMGLO PORTABLE AIR...
2004 CATERPILLAR 416D BACKHOE (A60429)
2004 CATERPILLAR...
PALLET OF CABINETS, TOOLBOXES, MISC NUTS & BOLTS (A63745)
PALLET OF...
