F935 PTO problem
   / F935 PTO problem #1
mb9ballr
newsoms,va
JD f935
Hello,
I have a f935 that was cutting just fine and as i was going along the PTO/blades just quit turning. Now the tractor won't start unless you jump the starter. It is like the tractor thinks the PTO is engaged but it isn't. Has anyone had this problem and what is the fix?
   / F935 PTO problem #2
Hello,
How old is it, what is the serial #.
   / F935 PTO problem
serial # on engine is ch3029d056840. Is that the one you seek? and i believe year model to be around 1990, not sure, bought it used. Worked great last summer. this first problem. 72" deck hope this helps you answer my needs
   / F935 PTO problem #4
Need the serial # of the unit, you find it on the right side frame rail beside the engine. The reason I ask is they changed the system for the mower/pto engagement. You likely have a lever to engage the mower. It uses a electromagnet to hold the mower engaged plus a switch on the lever system under the seat that keeps the magnet energized. My guess is the switch failed, got knocked out of adjustment or the wire disconnected or broke. If you lift the seat you will see the system that engages the pto. You will also see a switch attached to it. I would start there. Does the pto light function properly on the right console?
   / F935 PTO problem
Kuboman,
You are correct when i took the switch off and jumpered it everything works. Now off to the JD dealer to get a new switch! Thanks a million!!
   / F935 PTO problem #6
Kuboman,
Glad to help, these JD mowers are a first class mower and are quite easy to work on. I did have issues of parts availability on some items otherwise I would still have mine. Keeps them serviced and they will last a very long time.:thumbsup:
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB 1.5 Ton Crane Mechanics Truck (A52377)
2015 Ford F-350...
2012 CHANDLER 130 BBL STEEL VACUUM TRAILER (A53843)
2012 CHANDLER 130...
2025 Swict 78in Bucket Skid Steer Attachment (A53421)
2025 Swict 78in...
2007 FELLA SM350 3 PT DISC MOWER (A55301)
2007 FELLA SM350 3...
2007 INTERNATIONAL 4200 SBA 4X2 BUCKET TRUCK (A51406)
2007 INTERNATIONAL...
